Tune up, drove several miles, won't restart
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hossfeathers88, Sep 5, 2025 at 9:19 AM.
  1. Sep 5, 2025 at 9:19 AM
    Hossfeathers88
    Hossfeathers88 [OP] New Member
    Friday
    1996 Tacoma 2.4L 2wd
    Hi all,
    96 Tacoma 2WD 2.4L F2RZ-N83 engine. After a misfire in cyl 1 i changed plugs, wires, rotor button, distributor cap, and ignition coil. Fired right up, drive about 5 miles, no skip, ran great. 20 minutes later, it won't start. I changed ignition coils thinking i may have a bad one, but still no start. Tried starting fluid into the air box, it sputtered a bit, but never would start.
    Has anybody run into this before and/or have any suggestions for me? My better half is fussing because our trash needs taken to the dump!
    Thanks!
  2. Sep 5, 2025 at 9:24 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If it sputtered when shooting it with some starting fluid I would check the fuel filter or fuel pressure
  3. Sep 5, 2025 at 9:25 AM
    Not a golfer
    Not a golfer Well-Known Member
    Calgary, Alberta
    2012 TRD Sport Double Cab Barcelona Red
    Adding starting fliud and it sputtered tells me it could be fuel source problem
  4. Sep 5, 2025 at 9:56 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Did you forget to tighten a ground? I know I've left the plenum ground loose on my 5VZ after a tune up, it ran great until it didn't and I ended up stuck on the side of the road for 30 minutes til I figured out what I did.
    Not sure if there is a ground specific to the fuel system on a 2.4, but that could explain the symptoms.
  5. Sep 5, 2025 at 11:44 AM
    Glamisman
    Glamisman Well-Known Member
    Does the Check engine light illuminate during bulb check?
    ControlCar likes this.
