Tune up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RodneyC34, Feb 9, 2018.
  1. Feb 11, 2018 at 7:27 AM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Wow, those are bad. Is that at a 30k change interval? These motors are known to not like iridium plugs. Save your money and buy regular plugs.
  2. Feb 11, 2018 at 8:37 AM
    RodneyC34
    RodneyC34 [OP] Active Member
    Rodney
    Ky
    2006 Toyota Tacoma Prerunner TRD sport
    Got to take it to AutoZone this week before work and have them run a scanner on it, hopefully it’ll show the misfire and I can get the coils ordered, it has stock coils in them now, if I replace one I might as well replace all them right?.. I’ve ran the iridiums in my old 03 Dodge I had and it ran better, still sucked on gas mileage but it was a dodge. Going to clean the MAF sensor this week also, couldn’t get it last night started pouring rain right as I got the plugs changed out..
  3. Feb 11, 2018 at 10:36 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    02s don't read heat, they read 02
    RodneyC34[OP] likes this.
  4. Feb 11, 2018 at 11:50 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Yes but there’s a heating element inside to warm them up for efficiency. My 2002 had a faulty sensor with the element going out.
  5. Feb 11, 2018 at 1:43 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes but the sensor circuit shorting into the heater circuit would set a code and the pcm would simply stop looking at the 02s for fuel correction.
    ARB1977[QUOTED] likes this.
  6. Feb 12, 2018 at 12:02 PM
    RodneyC34
    Rodney
    Ky
    So I went and had it scanned today and the only thing it was picking up was a code P0430 which is catalyst system below threshold... could that be the jerking or is it something else...
  7. Feb 12, 2018 at 4:44 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    That usually is a bad cat on driver side. I had the same code a few weeks ago and replaced all 4 o2 sensors and light went off and fuel mileage has returned to normal. Worth doing instead of replacing a 1700$ cat
  8. Feb 12, 2018 at 5:03 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    101050 miles on them puppies, and even though the ground electrodes are a bit worn, the gap was good (I re-gapped at 80K) and the engine was as responsive as when new. I perceived no performance difference when I drove with the new Denso Long Life Iridiums. However, based on that wear, I would not know go past 80K on regular NKG Iridiums. The Densos have a hardened ground electrode and should outlast the NGKs. I will keep a closer eye on the wear. You saying about saving money ... ;)
  9. Feb 12, 2018 at 6:32 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    Where did you find a cat for 250 if you don' mind me asking?
  10. Feb 12, 2018 at 6:56 PM
    RodneyC34
    Rodney
    Ky
    I about crapped my pants when they told me 987.00 just for converter... I’ll deal with it for that price.
