Tune ups
Discussion in '1st Gen. Tacomas (1995-2004)' started by zeal, Mar 8, 2009.
  1. Mar 8, 2009 at 9:12 PM
    zeal
    zeal [OP] Member
    North Dakota
    99 Tacoma SR5 V6 3.4
    Hey guys I have a 99 tacoma 4x4 with the 3.4 in it. I'm getting real close to a hundred thousand miles. I was wondering if that is a interference engine (where if the timing belt breaks the pistons will bend the valves). I'm probably going to give it a tune up. Any ideas on what should and shouldn't be replaced, or advice in general to increase performance and life expectancy of the truck would appreciated.
    Thanks
  2. Mar 8, 2009 at 9:23 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i just did this at like 125K
    fuel filter
    spark plugs
    coolant exchange
    diff fluid
    adjust rear brakes(if not needing replacement)
    rotate and adjust air pressure
    tranny fluid if its been changed regularly
    seafoam also(before you change the plugs)
    timing belt is reccomended, but i dont have the money for it right now.. if you have the time and tools you can do it
  3. Mar 8, 2009 at 9:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The engine is a NON interferance motor, But, the belt should be replaced at 90,000 on the 3.4.
  4. Mar 8, 2009 at 9:30 PM
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    i should probably get on that then!
  5. Mar 8, 2009 at 9:34 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What Chris said about the timing belt, every 90K miles. Major maintenance is performed every 30K.
  6. Mar 9, 2009 at 7:55 AM
    zeal
    zeal [OP] Member
    North Dakota
    So when I tear in to get the timing belt out should I replace the water pump as well or should it be good for another 50k miles. Also can a guy time that motor? I don't know if it's possible assuming the timing is run by the computer. Just wondering if there is a trick to it.
  7. Mar 9, 2009 at 8:33 AM
    gonzo6up
    gonzo6up Well-Known Member
    Middle Tn
    09 tacoma SR5 4x4 sport
    tint/ vent visors/ seatbelt chime mod/ DTRL Mod
    might as well change water pump while you are in there. I'm not sure about a timming trick, all i did is mark TDC and hoped nothing moved.
  8. Mar 9, 2009 at 8:37 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    If you do the T-belt do the this as well.
    .1 T-belt
    2. Water pump
    3. Cam/crank seals
    4. Tensioner and Idler pullies as well.
    5. Belts/ hoses
    6. Radiator and Block flush.
    7. Oil Flush, with tranny atf fluid trick...
  9. Mar 9, 2009 at 8:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I screwed around with the timing on a Nissan, and first start, it threw a code. Only moved the timing one notch. I wouldnt recomend it.
  10. Mar 9, 2009 at 9:44 AM
    zeal
    zeal [OP] Member
    North Dakota
    Thanks guys. Any tips on what brand and/or type of (water pump, spark plugs, plug wires, belts, ect)
  11. Mar 9, 2009 at 10:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    oem.
  12. Mar 9, 2009 at 1:23 PM
    ubermx5
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    1.OEM if you find a whole sale deal.
    2.Plugs and and plug wires NGK if you can not get OEM...
    2. Gates or Good year as they are proven good. for belts and hoses
    OEM last the longest more of the time, but never pay full price...
  13. Mar 18, 2009 at 6:06 PM
    5vzrider00
    5vzrider00 Well-Known Member
    Lenoir, North Carolina
    2003 Tacoma
    K&N FIPK intake, leveled, Apexcone HID conversion, pro comp alloys, magnaflow exhaust
    I just replaced my timing belt
