Tune vs pedal commander? Help!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRD_Sporter17, Aug 30, 2024.
  1. Aug 30, 2024 at 7:39 PM
    TRD_Sporter17
    TRD_Sporter17 [OP] Member
    Chad
    Lancaster, PA
    2017 Blazing Blue Pearl Tacoma TRD Sport 4x4
    Body Armor hi-line series front bumper, XD grenade series wheels, AFE GT Momentum cold air intake
    Hi all! I’m pretty new to this site so rather than try to sort through a multitude of forums on here I’ll just ask the question to get some much needed feedback: Which would be the better choice with regards to getting either a tune or the pedal commander….or maybe even have both of them together?? Please share your thoughts! I’ve vaguely heard of OTT tune and OVTune for 3rd gen Tacomas but know nothing about them. My stock Tacoma definitely has throttle lag and eventually I’d like to start towing more with it so I’d like to know what my best options would be aside from changing out gears. TIA!
  2. Aug 30, 2024 at 7:47 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You will benefit from a tune much more than a pedal commander.
    A tune will tune the entire engine AND transmission, a pedal command won't.
    Spend the money on a tune. It will be WELL worth it.
    I recommend OTT. Not because they are "better".
    But because they have GREAT customer service.
    I don't even have a tune on my truck currently. And they still help me out when I have questions.
    Plus they are active on this forum.
    @Boltripper and @JustDSM are the 2 big guys on here from OTT.
    BoomerGVNG, ERod27 and Dm93 like this.
  3. Aug 30, 2024 at 7:50 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Pedal commander can only change the pedal input, and that pedal input is still interpreted by the ECM. Tune changes how the ECM thinks from the start and changes how the transmission implements all inputs.
  4. Aug 31, 2024 at 2:34 AM
    Travelinman301
    Travelinman301 4 x 4 Fanatic
    Florida
    2018 Blazing Blue Pearl Tacoma TRD Sport 4 x 4 DCSB
    KDMAX-PRO-10.0 Diode Dynamics Sport Fog Lights Morimoto Clear Tail Lights TRD Skid Plate
    Whichever tune you choose is a personal preference. I chose KDMax ( which is now YotaWerx) over 5 years ago and will never go back to stock.
    PapaRee likes this.
  5. Aug 31, 2024 at 6:51 AM
    tacoma04
    tacoma04 Retired to the lake
    Bruce
    Tennessee
    2017 TRD OR DCSB BBP
    If you will be towing, a tune for sure. I have KDMax 10 and the combination of the changes to engine performance AND transmission performance made a big difference. If I didn't have a tune, I would go with OTT tune. It is a good tune with very good customer service reputation.
  6. Aug 31, 2024 at 7:18 AM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    I have a Banks Throttle Monstor. It totally changed the dynamics of the truck including the transmission. After a couple hundred miles the transmission became very responsive. It has over 40 settings, reverts to stock in reverse so you don’t go ballistic in reverse and it has fail safe. Very easy to remove for warranty work or to sell when you trade the truck. Forget pedal commander it’s not even on the same level.
    If you don’t want to tune it’s a good alternative.
  7. Aug 31, 2024 at 7:19 AM
    3GTCMLMTD
    3GTCMLMTD Well-Known Member
    2022 Limited
    Go with the OTT tune and be done with it. You'll be much happier and won't have to worry about that pedal commander messing up your truck and sending it into limp mode or worse. It's rare, but it has happened to some.
  8. Aug 31, 2024 at 7:54 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Pedal commander is pure snake oil. It only boosts the signal from the throttle making the ecu think you're pushing the gas pedal harder.
    A tune will adjust the throttle sensitivity as well as make more horsepower and torque. It will also change the shift points to drive better on the highway
    MagicToolbox likes this.
  9. Aug 31, 2024 at 9:11 AM
    TRD_Sporter17
    Chad
    Lancaster, PA
    Thanks for this information. I did check out their website to read about the product. The only thing I question is because the fact it also plugs into my OBD port would be what type of splitter could I get to still have access to my port to attach a gauge scanner (I.e. scanguage 2 or 3)?
  10. Aug 31, 2024 at 9:12 AM
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    Tune it!
  11. Aug 31, 2024 at 9:14 AM
    TRD_Sporter17
    Chad
    Lancaster, PA
    How much roughly does the OTT tune cost? Does the tune ever need updated over time? The nearest authorized place that can offer this tune is about a 3-1/2 hour drive away from me.
  12. Aug 31, 2024 at 9:48 AM
    STEELeR43
    STEELeR43 Well-Known Member
    Hawaii
    2023 Tacoma TRD 4x4 6MT
    3" Icon Lift, SPC UCA, B&M Sport Shifter, OTT Tune
    You can contact tuner to confirm. $450 for OTT, either pay with VENMO, or cash to tuner. If needs update, or adjust tune free. I had my Tacoma tuned last month, I luv my truck.:D
  13. Aug 31, 2024 at 10:01 AM
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Pedal Commander is a band-aid, the Banks device is pretty much the same. A tune is the best route to go. I would recommend going into the Performance and Tuning forum and check out the various tuning options. There is a lot of info there, but it will give you a better idea of what's available and help you decide what would work better for you. Take your time and digest the info available and always ask questions. The main tuners are well represented on this site.
  14. Aug 31, 2024 at 10:21 AM
    TRD_Sporter17
    Chad
    Lancaster, PA
    Thanks I’ll check it out!
  15. Feb 18, 2025 at 6:50 AM
    Stone56
    Stone56 Well-Known Member
    Jeff
    2018 TRD Sport
    I called the closest tuner and maybe it was just him but he never answered a single question, he would only tell me how great it is.
    In order of preference, I'm looking to stop the engine braking I get when using cruise control in a hilly area, stop the dramatic downshifting to make up speed in cruise control, reduce throttle lag, improve MPG.
  16. Feb 19, 2025 at 10:12 AM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    We don't have anyone here that does tunes.
    I have been using a Sprint Booster for 4.5 years with no issues.
    It works great.
    2 years on my 2nd gen, and 2.5 years on my 2022
  17. Feb 20, 2025 at 5:12 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    I had the KD MAX tune since my truck was new. Now that I’m getting closer to my first emissions testing, I had OTT put their tune over the original. The reason for that was they now are carb compliant and there will be no issue checking my emissions with California. I honestly can’t say which one was better than the other, but I am still very happy with the way this truck turned out. It’s a crime that the factory doesn’t ship it like this.
    BoomerGVNG likes this.
  18. Feb 20, 2025 at 5:16 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    OTT mild/medium ALL THE WAY
  19. Feb 20, 2025 at 8:11 AM
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    I have the OTT do-it-yourself tune, and have been through three iterations.
    IMO, the tune is superb and I am 100% satisfied with it.
    However, the Tacoma has a big, horrible dead spot in the pedal from a dead stop.
    With a light foot, you push and push and push and get nothing.
    Then it slams forward with a lurch.
    This is present in both the stock factory tune and the different OTT tunes.
    Conversely, our 2016 RAV4 does NOT have this defect, and the pedal functions as you expect.
    I do not know if a pedal commander fixes this or not.
    But the OTT tune does not.
  20. Feb 20, 2025 at 8:21 AM
    BoomerGVNG
    2022 TRD SPORT DCSB
    the best is when you come to a stop at a light, it immediately turns green as your trans is downshifting, you hit the gas and the dead spot and the trans/torque converter makes a god awful clunk catching into gear. have to baby that first 10% of throttle!
