Tuner help
Discussion in 'Performance and Tuning' started by FrostyEldin, Dec 1, 2016.
  1. Dec 7, 2016 at 4:18 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The Timken bearings, while a third the cost of the OEM, did not have the reluctor ring for the ABS sensor. Therefore no ABS.
    inwood customs likes this.
  2. Dec 8, 2016 at 12:31 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    So that disables ABS through the whole truck? I'm pretty tempted to just pull the fuse. The plus side to the switch for me is disabling VSC And traction control as well IIRC.
    I need to research more into what ABS is all tied in to and what it effects if I cap off the module
  3. Dec 8, 2016 at 5:04 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct.
  4. Apr 25, 2017 at 9:01 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    So... Somehow just stumbled across this. Are we still trying to solve something here? Looks like Tor arrived so the answer key is here, but I'll certainly help if I can.
  5. Apr 25, 2017 at 9:12 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Stumbled right past post #11
  6. Apr 25, 2017 at 9:15 PM
    memario1214
    Colton
    Missoula, MT
    Yeah I never saw the tag to be honest... The OP disappeared though. Just giving him a second shot at getting an answer if he still needs one.
  7. Apr 25, 2017 at 9:22 PM
    inwood customs
    Dave
    Lol, sall good man :)
