Tuning and Headers!
Discussion in 'Performance and Tuning' started by cajuntaco, Jan 27, 2009.
  1. Jan 27, 2009 at 6:08 PM
    cajuntaco
    cajuntaco [OP] Well-Known Member
    Lake Jackson, Tx
    08 Tacoma 4x4, Banks Exhaust
    Banks Exhaust, Removed Secondary Filter, Toyota factory suspension upgrade. 265/75 Interco TRXus M/T's
    I will be purchasing headers soon, and have decided on doug Thorley. I just dont know if I want the shorties or the TRI-Y. About what am I looking at for installation. (Does anyone know of someone who is good and reliable in the Houston area?) Where can I get my computer tuned, again someone good and reliable and in the houston area preferably. Thanks again, and look forward to yall's replies they are always helpful.
    Dustin
  2. Jan 28, 2009 at 8:13 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    There was just a real big mod day in Houston a couple weeks ago. Mostly X-Runners, but we had some pre-runners there as well.
    If you are looking for performance, get the Doug Thorley long tubes. Install is pretty straight forward, and there are a ton of guys in the Houston area that will help out. Mostly XR owners as I said, but all we do is mod vehicles, so you are more then welcome.
    As far as tuning the ECU, there are a few options. For the best tune and best performance the APR X-1, though it is a bit on the costly side, it is well worth the money. But the URD MAF Calibrator is a good, inexpensive alternative.
  3. Jan 28, 2009 at 9:49 AM
    cajuntaco
    Lake Jackson, Tx
    With the long tubes, would I have to relocate my CAT's?
  4. Jan 28, 2009 at 9:51 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    The long tubes remove the front set of cats. So it may or may not pass emissions, will depend on the test being administered.
    The shorty's will keep the cats in the stock position. Like I said if you want performance the Long Tubes are better. You will still see some gains from the shorty's, but not nearly as much.
  5. Jan 28, 2009 at 9:54 AM
    cajuntaco
    Lake Jackson, Tx
    Well this is my everyday driver. I know I could get away with it back home in Louisiana, but I dont want to really chance in in the Houston area. But at the same everybody wants as much perfomance increase as possible.
  6. Jan 28, 2009 at 10:50 AM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    I know a guy in Houston that has a pre-runner with TRD s/c, intake, long tubes, and catback, that just passed emissions. Not sure where he went or what he did.. but it was done.
  7. Feb 5, 2009 at 10:30 AM
    cajuntaco
    Lake Jackson, Tx
    I was told it you go to the right place and pay the right amount of money (about 125) your truck will pass emissions
  8. Feb 7, 2009 at 1:21 PM
    2009tacomav6
    2009tacomav6 Well-Known Member
    phx AZ
    2012 4x4
    TRD SC TRD Cat Back KMC 17x9 Addicts
    I would really like to get some headers too but I have heard with the cats so close to the engine, performance gain is negligible.
  9. Feb 7, 2009 at 6:29 PM
    cajuntaco
    Lake Jackson, Tx
    Every little bit helps and its all part of a long term project.
  10. Feb 7, 2009 at 6:36 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    If xrunnit says its so you can take that to the bank. Its a been there done that kinda deal.
  11. Feb 10, 2009 at 8:51 PM
    Coupe
    Coupe Well-Known Member
    Houston, Texas
    08 X-Runner
    Lots baby!
    Most inspection shops are looking for a code error. A knowledgeable inspector will know you have installed headers. However, unless they are familiar with Tacomas, they may not pick up on the four cat vs two cats.
    I wrangled with this and went with the JBAs. It's a harder install, but no worries with the cats.
