Tuning my Cb
Discussion in 'Technical Chat' started by NewRider, Apr 2, 2014.
  1. Apr 2, 2014 at 7:28 PM
    NewRider
    NewRider [OP] Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    I'm having trouble gettin my CB antenna tuned. I've read extensively on how to do and have installed an SWR in-line to do so but just can't get this thing under the 1.5 max.
    Gear/setup:
    Cobra 19 (stealth install into center console)
    the instal required a right angle coax plug between the dado and the wire if that makes a huge difference
    18' firestik, firering coax cable (carefully run through the grommet in the rest of my cab)
    custom/homemade bed mount. I did this with a piece of steel flat bar, simple bend and screwed directly to the bed with the two bolts just inside the tailgate on the passenger side. it was originally clear coated but I have sense sanded the areas around the screws and coax connections to provide good ground.
    I've been careful to instal the fire ring cable per firstik's instructions to I don't believe that to be the issue. I've also been careful to not coil the excess cable, it is in an "s" pattern under the carpet of the rear floorboard. from there it runs through a hole into the storage compartments under my rear seat to the SWR meter, then from there to the CB installed in the center console.
    As I said, I've read extensively on setup and tuning of these antenna's and believe I've don't everything right, I just can't seem to get it with a reading under 1.5. The only thing I haven't done is to try moving the antenna, I don't really mind doing this but I'd prefer to try EVERYTHING else first as it will require me to remove a lot of plastics and the rear seat to get enough coax out to get to the other side of the truck or really any other location.
    so that's my story... any input?
  2. Apr 2, 2014 at 7:36 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    1.5 is really not that bad if that's what it is. My cb's swr's change frequently. If the truck is wet, it's about 1.7. Dry about 1.3. I think the rule is under 2 you're safe from any damage
  3. Apr 2, 2014 at 9:21 PM
    Pakrat
    Pakrat Well-Known Member
    Brian
    Washington,State Columbia gorge
    02 tacoma xtracab 4x4 stock
    Front dome light added,light reminder added,door chime mod, added 2nd gen 4runner headrests,grey wire mod, 2lo mod, more later.
    Do you have 1.5 on all forty channels? If so I'd take that and run. It's tough to get a 1.1 swr. The best I can get is 1.8 with a 3foot firestik 2 and 18 feet of new coax but my firestik is mounted on my left front fender, one thing to try is checking your swr with no obstructions nearby such as buildings other vehicles ect.If you have a 1.5 swr on all 40 channels that is 95% out 100 power output and receive. Hope this helps you.
  4. Apr 3, 2014 at 2:28 PM
    NewRider
    Travis
    '87 4runner
    I can't get my set to stay or get under 2-3 on ch.1 or 40... If it was stayin under or around 1.5 I'd be happy but ya... It was so bad this last trip that I could hear either of the two guys with me hardly at all, they could both hear each other and me clearly
  5. Apr 3, 2014 at 2:45 PM
    smmarine
    Melbourne FL
    Make sure your coax is good. Make sure your ground is good all the way to the battery. I had a problem where my negative battery terminal was corroded so the truck had a ground problem
  6. Apr 3, 2014 at 2:59 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Waaaaaaiiiiiiitttttt.
    They can hear YOU fine, but you can't hear them???
    That would seem to indicate you're tranmitting OK and don't have an SWR problem. SWR approximately equal to 2 won't keep you from hearing the other guys.
    Stupid first thing to check - your squelch isn't turned up too high?
    Stupid second thing to check - your radio doesn't have some funky privacy setting like all the FRS radios do?
    Can you hear the WX stations OK? That would rule out a speaker wiring problem.
    After that, I'd tend to suspect an internal problem in the radio.
  7. Apr 3, 2014 at 6:02 PM
    NewRider
    Travis
    '87 4runner
    I'm gonna triple check my ground at the antenna bi I know he one at the radio and the one at the battery are good, both very clean and well connected..
    Squelch is turned down, not the issue. Radio doesn't have WX or other settings so that can't be it either...
  8. Apr 3, 2014 at 6:05 PM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    could be just your radio, try one of your buddys radio.
  9. Apr 4, 2014 at 6:28 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Try changing out your mic. Also make sure it's not sticking in TX.
