Tuning Sub Amp
Discussion in 'Audio & Video' started by Blade-Runner, May 19, 2010.
  1. May 19, 2010 at 1:09 PM
    Blade-Runner
    Blade-Runner [OP] Well-Known Member
    Kevin
    Las Vegas, NV
    08 TRD Sport Prerunner
    Performance: - TRD Supercharger - URD 2.85 Pulley - APR X-1 - Doug Thorley long tube headers - Magnaflow CAT back - Toytec 3" lift Audio: - Damplifier Pro, doors (x2), rear wall, floor, kick panel & firewall - JL 13TW5 - Polk Audio db6501 - Polk Audio db5251 - Alpine PDX 1.600 & 4.100 - Pioneer AVH-P4200DVD
    Been trying to get my sub amp tuned in good and I have a question.
    I have the Pioneer AVH-P4200DVD which has a built in sub crossover and is connect to an Alpine PDX 1.600 which also has a built in crossover. I can't diable/turn off one or the other, so which should I use and what should I have the other set at?
    Thanks,
    Kevin
  2. May 19, 2010 at 1:29 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'd use the one on the headunit and then set the one on the amp as high as it will go so it's really not being used.
  3. May 19, 2010 at 1:32 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    not sure if this helps your situation but what I do is set my hi pass on my deck to 150 hz and my low pass on my amp to 150 hz then the subs take care of all the bass and my speakers will last for ever.
    using both cross overs on your deck and your amp wont hurt anything
  4. May 19, 2010 at 4:25 PM
    orvis
    orvis Well-Known Member
    Winnipeg, Canada
    06 TRD off road
    I would set the low pass on the amp to 200 hz and play with the low pass on the hu, every vehicle is different and every hu/amp/sub set up is different and the best way to find what works with yours is to play with it.
    What box are you using?
