Tuning
Discussion in 'Performance and Tuning' started by myming, May 10, 2018.
  1. May 10, 2018 at 9:29 AM
    myming
    myming [OP] Member
    4x2 sr5
    hello all,
    i have a 2004 tacoma extended cab, long bed. 33,000 miles, stock, except for titanium spark plugs and one front end alignment. i change my oil every 3,000 miles and flushed out my
    radiator and refilled with anti-freeze/water.
    i was told that it doesn't need to be tuned until i reach 100,000 miles. that seems to be
    rather a long time to me.
    it drives as it did when i bought it. no engine problems.
    do i NEED to do a tuneup ?
    thank you.
  2. May 10, 2018 at 10:00 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Your '04 only has 33k miles?! :bowdown:
  3. May 10, 2018 at 10:49 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Like holy shit man. Did you just come here to brag??? LOL Anyway, I once bought a Tacoma with 255k miles on it, ORIGINAL spark plugs, I'm not even kidding. Denso in one bank and NGK in the other. You'll be fine I think!
    what you NEED to do is drive that sumbitch
