turbo header
Discussion in 'Performance and Tuning' started by coma98, Jul 7, 2013.
  1. Jul 7, 2013 at 8:16 AM
    coma98
    coma98 [OP] Well-Known Member
    zach
    ky
    98' built 2rz turbo
    Lowered 4/5 Stage 4 clutch. Fidanza flywheel. W58 trans, arias pistons, pauter rods, arp mains an head studs, cosmetic gasket, T3/t4 15psi and more coming!
    I'm needing a new Turbo header, after 2 months mine is cracked. Does anybody on here make them or know somebody who does? I need one ASAP
  2. Jul 7, 2013 at 10:14 AM
    Gadget@URD
    Gadget@URD Well-Known Member Vendor
    Southern Maryland USA
    URD Supercharged XRunner
    What truck, engine, and year do you have?
    G
  3. Jul 7, 2013 at 3:38 PM
    coma98
    zach
    ky
    98' built 2rz turbo
    98, 2rz
  4. Jul 7, 2013 at 4:18 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Not a fan of LCEngineering are you? Also try hitting up Paradise Racing.
  5. Jul 7, 2013 at 4:55 PM
    coma98
    zach
    ky
    98' built 2rz turbo
    No me neither I haven had much luck with them, well there's start out at $850, Louis is a good Guy but I'd rather not spend that much unless I have to. It's kinda leaning that way tho ..
  6. Jul 7, 2013 at 5:46 PM
    noSKills858
    Alex
    Poway, CA
    Well if you can find a shop that builds custom headers they should be able to copy your current manifold. Is it too messed up to patch up with a weld?
  7. Jul 7, 2013 at 6:35 PM
    coma98
    zach
    ky
    98' built 2rz turbo
    It can be welded, I was gonna buy one an then have this one welded an kept as a spare. Since I've got like 3 of everything lol
    Its hard to find people around here who can weld it is the problem. I'll have to ship it off probably.
  8. Jul 7, 2013 at 7:22 PM
    noSKills858
    Alex
    Poway, CA
    As much as I'd hate to say it, try craigslist.
    Btw who did your turbo setup?
  9. Jul 7, 2013 at 10:00 PM
    coma98
    zach
    ky
    98' built 2rz turbo
    I pieced it togather. I bought the piping an intercooler off eBay an the Turbo off of a 240. It was kinda simple, it would of been a little easier/cheaper if it was a 2000-04.
    I recently jus bought a trans from a supra and a LSD I'm getn ready to put in. I'm going to big to soon, I'm just bout out of stuff to do to it.
  10. Jul 8, 2013 at 9:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  11. Jul 12, 2013 at 4:34 PM
    noSKills858
    Alex
    Poway, CA
    Which trans did you get, the R154?
  12. Jul 13, 2013 at 7:59 AM
    coma98
    zach
    ky
    98' built 2rz turbo
    W58 out of a supra, swap bell housings an its direct bolt up. Gets rid of the short ass 1st gear, with 3:73 1st gear at Rev box is 45 mph, vs 25-30 with the stock w59.
