Turbo high flow Fuel pump
Discussion in '1st Gen. Tacomas (1995-2004)' started by farmer_kyle, Mar 5, 2017.
  1. Mar 5, 2017 at 1:12 PM
    farmer_kyle
    farmer_kyle [OP] Well-Known Member
    2004 Tacoma sr5
    3.5" (adjusted to 4.5") fabtech suspension lift. 15x8 procomp 252 crawlers. 32x11.5 BFG Ko2's.
    Hey guys. Just finished installing my turbo in my 2004 v6 taco. I have trd 440cc supercharger injectors but need a bigger fuel pump to keep me boosting through 7psi. That's when it starts to show up as lean on the computer. I was looking at aem fuel pumps. Do I need to get a offset inlet or a center inlet fuel pump? If you have a different fuel pump you would recommend to fit my truck, I'm open to suggestions. Thanks
  2. Mar 6, 2017 at 8:33 AM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    GT35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 255/55r18 street, 255/60r16 M&H Racemasters, 7.8 at 93
    No, you absolutely don't need a bigger fuel pump yet. I am running 9psi on 550cc injectors and haven't hit limits of stock fuel pump. You need something to tune with immediately. I highly recommend AEM-F/IC 6
  3. Mar 6, 2017 at 9:55 AM
    farmer_kyle
    2004 Tacoma sr5
    I have the fic 6 wired in and working. I only have 440cc injectors and my wastegate is set to 10 or 12 psi. Obviously, I'm going to turn it down before I really get on it but the tuning shop shows a going really lean high in boost
  4. Mar 6, 2017 at 11:15 AM
    Exhaust
    Exhaust Well-Known Member
    Erik
    Wharton State Forest
    02 DC TRD
    Extended breather, Grey Wire mod, Tundra brakes, Rockford-Fosgate sound, General Spring HDs, 5100s + 880s, Heated Seats, TRD Supercharger, 2.1 Pulley, URD 7th Kit
    Doesn't necessarily mean you're fuel pump is leaning it out. I'm pulling ~10psi with a 2.1 pulley and 7th injector and the stock fuel pump holds fine. The injectors sound like your bottleneck
  5. Mar 6, 2017 at 11:16 AM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Is there some way to can check your Fuel Pressure?
  6. Mar 6, 2017 at 11:19 AM
    Exhaust
    Erik
    02 DC TRD
    They do have fuel pressure test kits but having never used one I don't know if it would work here.
  7. Apr 29, 2017 at 7:57 PM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 680k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 680,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, rebuilt 3 times over 500,000 miles, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley,(300hp) (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, 4runner bucket seats, Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks chrome push bar, chrome nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Corbeau bucket seats Snow Methonal kit stage 2 Champion 3 core aluminum radiator Linex bed liner Haltech stand alone ECU
    I'm thinking of getting larger injectors, with a stock fuel pump 550 will work ok?
    What injector did you get and where?? Did you need an adapter for the wires?
  8. Apr 29, 2017 at 8:44 PM
    boostedka
    James
    NM
    Are you going to use a piggy back or something to tune them with?
  9. Apr 29, 2017 at 8:56 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    http://www.ebay.com/itm/550cc-Toyot...ash=item2cbd9e88b6:g:zkoAAOxy83JRG13L&vxp=mtr exactly what I got. They idle and run perfectly, never know the difference from stock. AFR wandereds at aroudn 1800 to 2k rpm under light load but that's due to the relocated position of the stock wideband o2 sensor. It doesn't do well in a 3" downpipe. The injectors have been flawless and they come with additional pigtails but the stock ones plug right in. I tune with AEM F/IC-6 and can't recommend it enough, it's been a pleasure to tune and log with.
    Oh yeah and I'm still on stock fuel pump and pushing 9psi (peak 10 sometimes according to logs)
  10. Apr 29, 2017 at 9:13 PM
    1997tacomav6
    Denver
    Well, I'm trying to find my trucks sweet spot on the supercharger with pulley size and
    boost using the stock ECU. I have been running 2.1 pulley with zero
    ping issues at Arond 6000 feet but only puts out 7 pounds of boost.
    So bought a pulleyboys pulley 2" to experiment with. The 2" pulley
    is putting out 10 pounds, (big power difference) of boost at 6000 feet, but pings only when
    the truck is lugging, no pinging at high rpms, just when in a high gear with
    low rpms, so was thinking maybe larger injectors will fix that problem,
  11. Apr 29, 2017 at 9:17 PM
    1997tacomav6
    Denver
    Ok great, if I use my ECU is 550 to large, I was running 2.1 pulley with 7 pounds of boost at 6000 feet
    with zero issues, no pinging, now I'm experimenting with 2" pulley and have some pinging when on load with low rpm, high rpms there is no pinging and shows 10 pounds at 6000 feet, are you turbo???
  12. Apr 29, 2017 at 9:20 PM
    boostedka
    James
    NM
    Sounds like you will need to be able to pull some timing in the lower RPM ranges.
  13. Apr 29, 2017 at 9:21 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Yeah man for sure gotta upgrade your ECU if you want to run these. The absolutely will not idle on your stock ECU. I'm pulling -58% fuel from the vacuum portions just to make it idle. The next step is gonna cost ya LOL. The AEM F/IC-6 can be had for around $380 on Amazon so around $700 for injectors and computer (if you can tune it yourself)
    1997tacomav6 likes this.
  14. Apr 29, 2017 at 9:23 PM
    1997tacomav6
    Denver
    Ok, well the truck is running great on the 2" pulley, no issues except when my rpms are low and I'm in a high gear, lugging the truck
  15. Apr 29, 2017 at 9:23 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Not sure what your setup is, but I can tune closed loop boost, so at -1psi I start enriching the fuel to 13.5 AFR. But 0 vacuum I'm at 13.0, and 1psi it drop to 12.5 and keeps dropping until I hit 10.5 at 9psi (rich, I know) but I have no pinging problems whatsoever and also I only run 93 octane ethanol free fuel. No timing pull necessary. I do pull 1* on the top end just because I'm a scaredy cat.
  16. Apr 29, 2017 at 9:24 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    Also I run an auto on ECT mode and it won't really let me lug it, so another win there.
  17. Apr 29, 2017 at 9:29 PM
    1997tacomav6
    Denver
    Maybe I will try a 2.050" 52mm pulley next, sounds like that will be my sweet spot for my ECU on my truck. I'm a little nerve pushing the engine at redline with the 2" pulley without bigger injectors and or an upgraded ECU. I was surprised about
    how much more power and boost I got with a 2" pulley
  18. Apr 29, 2017 at 9:34 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    If you're wanting to stay with stock ECU and I can't blame you, get a progressive methanol injection setup. Coolingmist makes a beautiful one (I have it) and you can set it to start spraying at 1psi and ramp up to whatever PSI you're pushing. You can spray blue windshield fluid and even 100% methanol. That would great increase your octane rating cool combustion temp (all of which will net you a sweet HP increase) and likely quit your detonation probs. Also make sure you're useing BKR6E plugs. You don't need to be using the stockers anymore once you go past stock pulley.
  19. Apr 29, 2017 at 9:37 PM
    boostedka
    James
    NM
    There was someone not too long ago on T4R.org selling an FIC that was set up to be PNP for a S/C 5vz. You could probably do searching around on there if you're interested in it
  20. Apr 29, 2017 at 9:38 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Whats the LPH of the OEM pump, and how much brake hp is your engine making?
