Turbo Install
Discussion in 'Performance and Tuning' started by Hoyt, Aug 12, 2011.
  1. Sep 23, 2011 at 9:01 AM
    #41
    MadMtnMikey
    MadMtnMikey Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Oh, right, sorry I thought you were comparing to supercharger. Yes, a turbo mounted right off of the manifold will definitely shine better than one that is downstream more. You're still going to get good performance though unless like I said, if you're going for all out HP and responsiveness.
  2. Sep 23, 2011 at 9:11 AM
    #42
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Update on OP's system??
    Hey WHipper!! S/c's installed and fucking beautiful :D :D :D
  3. Sep 23, 2011 at 10:37 AM
    #43
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  4. Sep 23, 2011 at 10:47 AM
    #44
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    sooooooooooooooooooo amazing, used to hit wind wall at around 185*, now it pulls so hard all the way that it actually bounces off the governor at 215*. Gonna have to remove that pesky thing soon....
    *Closed course in Mexico
  5. Sep 24, 2011 at 10:44 AM
    #45
    Hoyt
    Hoyt [OP] Well-Known Member
    Green Cove Springs,FL
    03' SR5
    Fabtech Dirt Logic 6" OME 881 Springs Custom Leather Spidertrax Wheel Spacers Deaver Leaf Pack Light Racing UCA's Diff breather mod Scangauge II Doug Thorley Headers Magnaflow Exhaust TRD Supercharger AEM Intake Transmission Cooler ARE Topper Relentless Armour IPT Valve Body Smittybilt X2O 8000 w/ 12 Volt Guy incab controller URD 7th injector Kit AEM Water Methonal Injection Kit Devil Horns Smittybilt Air Compressor
    All parts are in so I am dropping the truck off Monday so I should have pics next weekend. The headers are back from the machine shop as well. Checked the HP in the truck this week and it was at 203, so we will see what happens.
  6. Sep 24, 2011 at 10:46 AM
    #46
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    nice! Do you have pics of the truck in general?
  7. Sep 26, 2011 at 3:45 PM
    #47
    Hoyt
    03' SR5
    I put my eyes on the water to air innercooler today so I think the truck will really be finished this week. :D
  8. Oct 2, 2011 at 12:23 PM
    #48
    Hoyt
    03' SR5
    Still no truck:mad:
  9. Oct 2, 2011 at 12:31 PM
    #49
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Be patient. When I was getting my integra engine built and turbo'ed it took a few months. But it was worth it in the end.
  10. Oct 2, 2011 at 12:43 PM
    #50
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    So the throttle body sits downstream of the supercharger and intercooler? That should result in good throttle response, potentially better than the TRD supercharger.
  11. Oct 2, 2011 at 1:03 PM
    #51
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yup, thats how my setups designed, Night and day difference, I've got a boost gauge coming in the mail to tell me exactly home much boost I actually am pushing
  12. Oct 3, 2011 at 4:00 PM
    #52
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    The throttle body is in the stock location. It is attached to the stock intake manifold.
  13. Oct 3, 2011 at 4:05 PM
    #53
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    x2, you'd have to hook up a boost gauge to a downstream section of the TRD charger
  14. Oct 3, 2011 at 4:06 PM
    #54
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Not here to butt heads with you, but i had the sts kit. Modified the crap out of it. It still sucked. Best I could get out of it was 412 whp and 507 wtq @ 14.xx psi, but it had an hp/tq curve that looked like a mountain. Up then back down. Wouldn't even spool up in first gear. Useless.
    Made an exhaust manifold for my turbo and mounted it up front. Makes more power per pound of boost and continually climbs. 475 whp and 549 wtq @ 14.8 psi. Full boost at 3400 rpms.
    What i want to see is how this OP's kit looks though.
  15. Oct 3, 2011 at 4:16 PM
    #55
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That is what i would have though as well. But my original turbo that came with the kit was smaller than the one I replaced it with, which I am still running. This one has a larger A/R turbine housing as well. So that should mean a little slower spool, right? Nope. Spooled faster with this one, yet still did not perform like it does now.
    I poured my heart, sweat and wallet into that kit, to make it as good as I could. Still paled in comparison. However, a mid mount should do quite well, since the engine bay temps will stay lower than a front mount, and you can get pretty close to equal length headers into it. You are only limited by the size of the turbo since there isn't much room down there.
    What size motor does the OP have? I forgot. Mine is a 4.0.
  16. Oct 3, 2011 at 4:17 PM
    #56
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There is also a guy on XRU that is trying to get the tuning bugs figured out in his recently installed mid mount kit. He has an Xrunner.
  17. Oct 3, 2011 at 6:11 PM
    #57
    KenLyns
    Belly of the Beast
    All else being equal, you want the throttle body to be as close as possible to the intake runners for the best throttle response. If the blower is after the throttle body, when the throttle opens, the air has to fill the blower, get compressed, fill the intake plenum, then go into the intake runners. Having less volume after the throttle is a good thing.
    Ideally you'd want individual butterfly valves inside each intake runner, though most production cars don't do it for cost reasons.
    BMW E39 M5 engine:
    Honda CBR 600F4i engine:
  18. Oct 3, 2011 at 10:09 PM
    #58
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    so are you saying blower before or after throttle body is better?
  19. Oct 3, 2011 at 10:13 PM
    #59
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
  20. Oct 3, 2011 at 10:13 PM
    #60
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I thought thats what he meant, but then i lost track
