Turbo install
Discussion in 'New Members' started by Jstand, Jan 26, 2017.
  1. Mar 18, 2017 at 4:26 PM
    #41
    Jstand
    Jstand [OP] Well-Known Member
    Irving,Tx
    2011 Tacoma DC TRD SR5 4x4
    IMG_5455.jpg IMG_5454.jpg IMG_5453.jpg Here's what I got today and where I'm at so far any comments are welcome that would be helpful for me or anyone who sees this. Is the wastegate piping ok like that ?
    MarX and Brice like this.
  2. Mar 18, 2017 at 5:54 PM
    #42
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Looks to me to be pretty nicely done. With the wg entering the dp at a 90* angle it will Probably create some restriction. May be super significant in your end result depending on your goals with the set up. Maybe some of the turbo guys on here can comment on your work with better input.
    @MadTaco461 @Clay @MrCrowntown @Torspd @Brice @GreeGunc
    @Clay_916
    MarX, Brice, Jstand[OP] and 1 other person like this.
  3. Mar 18, 2017 at 6:37 PM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    To be honest. I say grind the welds, get the down pipe where you need it, and tack it in place. At the same time fix the wastegate dump tube to have more of a steeper re-entry angle into the the downpipe.
    Otherwise it will create a back pressure against the flow of the downpipe's exhaust.
    MarX and Jstand[OP] like this.
  4. Mar 18, 2017 at 7:08 PM
    #44
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    You'll be fine with the low boost stuff. You might start getting issues around 8-10psi.
    Ideal is to enter the exhaust as close to parallel with the flow. Worst case you can dump it as a screamer.
  5. Mar 18, 2017 at 7:50 PM
    #45
    Jstand
    Irving,Tx
    Thanks everyone for the input I'll probably try it like it is on low boost just to get started and then reconstruct later and i'm going to stay below 7psi with no intercooler
    MarX, Brice, Torspd and 1 other person like this.
  6. Mar 18, 2017 at 8:36 PM
    #46
    Jstand
    Irving,Tx
    On second thought I better fix the wastegate pipe first
    MarX, Brice and Torspd like this.
  7. Mar 18, 2017 at 9:08 PM
    #47
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    The wastegate angle into the dump pipe, like others have said, isn't the best but should be ok. But I'm late and it seems like you're gonna change it :D Nice build! You could always just dump into atmo;)
  8. Mar 18, 2017 at 9:08 PM
    #48
    Brice
    Brice Turbo Member
    Brice
    Texas
    Are you gonna do meth? Not needed but I'm told it makes a big difference
    Also I aint no welding expert but your welds seem a bit cold, I don't know what you're working with but amping up the heat can make a big difference :D
    dually and jviffer like this.
  9. Mar 18, 2017 at 9:26 PM
    #49
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Angle that dangle, like everyone has recommended already lol
    And is the downpipe touching the header?
  10. Mar 18, 2017 at 10:19 PM
    #50
    Jstand
    Irving,Tx
    Sucks having to cut that pipe and then patch it and re-weld right under it but probably worth it
    yes it is
  11. Mar 18, 2017 at 10:31 PM
    #51
    MrCrowntown
    Alyn
    Ky
    You want to promote flow towords the end of the down pipe. If you have turbulance at that intersection, you may have problems controlling boost.
    Jstand[QUOTED][OP] likes this.
  12. Mar 19, 2017 at 7:56 AM
    #52
    MadTaco461
    CA
    Kinda stock
    Good first try at this. Thin wall tubing is a pain to do with a flux core. You probably won't have any issues with the welds for a while as long as you aren't putting any stress on the pipes from the hangers.
    I still suck at mig welding thin tubes and my welder is a pretty good one. A good tip I've learned. Tack every 90 degrees around the tube. Weld in 90 degree phases. Say 12 to 3. Take a break to let the pipe cool down. Weld 6 to 9. Take a break. Prevents holes being blown through. I haven't tried it yet, but my buddy said to try .025" wire. You aren't dumping so much heat into the metal and keeping the heat more localized. Just something to try if you are welding with some scrap ends. A good tig welder would fix all our diy problems.
    Jstand[OP], Torspd and boostedka like this.
  13. Mar 23, 2017 at 12:55 PM
    #53
    Jstand
    Irving,Tx
    IMG_5465.jpg IMG_5466.jpg IMG_5467.jpg OK this is what it looks like now big mess but hopefully it'll work.
  14. Mar 23, 2017 at 12:57 PM
    #54
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    that plate man... nice patch!
    MarX and Jstand[QUOTED][OP] like this.
  15. Mar 23, 2017 at 12:57 PM
    #55
    MrCrowntown
    Alyn
    Ky
    YASSSSS! Looks great buddy
  16. Mar 23, 2017 at 1:13 PM
    #56
    boostedka
    James
    NM
    That should work much better than your previous setup. Nice job!
  17. Mar 23, 2017 at 3:31 PM
    #57
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Waaaay nicer! Beautiful!
    Jstand[OP] and MarX like this.
  18. Mar 23, 2017 at 4:05 PM
    #58
    MadTaco461
    CA
    Kinda stock
    I'm here waiting for spool sounds.
    Jstand[OP], MarX, boostedka and 2 others like this.
  19. Mar 23, 2017 at 5:01 PM
    #59
    boostedka
    James
    NM
    Hopefully this will appease for now
  20. Mar 23, 2017 at 5:21 PM
    #60
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    Impressive work
