Turbo: is there a complete kit out there?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by patrickockander, Jan 14, 2009.
  1. Jan 14, 2009 at 3:14 PM
    patrickockander
    patrickockander [OP] Say What?
    Patrick
    San Antonio, TX
    TACOMA TRD Offroad version 4x4
    Supercharged, Hood Lift-struts, Borlas, 2-tone Leather, Husky Liners, 16" Completely rewired audio system, Components front/rear, Dbl Limo Tint, 2-din JVC KWNX7000BT (DVD+GPS), TRD CAI, disabled seatbelt alarm, E3 Plugs, Halo Headlights, Tuck-in style Rain guards, dealer sticker removed, Step rail,
    Anybody know much about this? I've got a 2008 Toyota Tacoma 4.0 V6 4x4 dbl cab that I want to install a turbo on. I don't know much about this, I'm mechanically inclined, and would like to purchase a complete kit if one exists...that is quality...can anyone point me in the right direction?
    any idea of what it might cost...final cost?
    Thanks in advance,
    Pat
  2. Jan 14, 2009 at 3:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
  3. Jan 14, 2009 at 3:54 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Out of curiosity....... since you have the V6 why not get the TRD supercharger?
  4. Jan 14, 2009 at 4:04 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
  5. Jan 14, 2009 at 4:24 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    http://oi.b5z.net/i/u/1473169/i/pdfs/STSFACT_06TACOMA_02_Final.pdf
    Funny how they cut the graph short 1k at the beginning of each pull on the STS, while they have essentially a full pull for the TRD SC. Obviously that TRD Sc will blow the STS out of the water in your lower range RPMs. Interesting marketing technique.
    With that said its looks like a great system, especially if it works on your 2.7's where a SC isn't available.. Although I would think someone has probably put a centrifugal supercharger on the 2.7:confused:
  6. Jan 14, 2009 at 4:45 PM
    sonjay
    sonjay Well-Known Member
    ^ Explain to me why the SC would blow the STS on lower RPM's? With such low boost that turbo is probably making full boost well before 2000 RPM. Its also cheaper, and more reliable I would think, no belts to change. A blower sounds pretty cool though!
  7. Jan 14, 2009 at 4:45 PM
    patrickockander
    Patrick
    San Antonio, TX
    I'm thinking about fuel economy....what do you say?
  8. Jan 14, 2009 at 4:54 PM
    AUDITECH
    AUDITECH Carolina Alliance: LAZY DIVISION
    charlotte nc
    07 double cab prerunner
    none
    Ok hera goes once and for all. The supercharger is run off a belt and pully system therefor it is always running and gets instant boost. Put with a supercharger your loosing about 20 horses about in our case using the engine to rotate the supercharger. Good low end torque and instant power but takes power to make it and is always putting a load on the engine just a little bit in this case
    The turbo is nothing but pure power. The turbo is turned by the exhaust doesnt go into boost unless you put the engine under a load full throttle or pulling. Hince the turbo lag or not so good lowe rpm power. But if you are easy with the throttle its like the turbo is not there and can possible keep the same gas millage if you dont hot dog all the time.
    My choice will always be the turbo the new systems have almost no lag and they are not always putting out boost.
    I had an article in a hot rod mag the test was a paxton supercharger and a roots magnacharger and a turbo. the turbo mad 30-40 more horsepower than the superchargers at the same boost.
    if anymore questions just send me a pm
    also sts has been building kits for corvettes and f body cars for a long time good stuff
  9. Jan 14, 2009 at 5:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have been in this discusion too many times. A turbo has no impact on the engine, parasitic wise? Are you sure about that? Viewed from an engines perspective, a turbo is a blockage in the exhaust system. Its not "Free" hp. I have tested this extensivly, and a turbo DOES, in fact, have a parasitic drag to the engine. The last test I did on one, there was over 15 hp drag. Modern superchargers have bypass valves and are not always under boost. And the design of the supercharger is pretty efficient. A modern supercharger has similar performance capabilities as a turbo, or better. The new Chevy Corvette uses a supercharger, if turbos are the "Be all and end all" of power, why didnt they choose a turbo? ;)
  10. Jan 14, 2009 at 5:28 PM
    SC4333
    Grant
    San Antonio, TX
    If you have yet to understand this simple concept, you should do a little research before firing off. Seems to me that came off a little rudely too.. There is plenty of research out there to substantiate exactly what I stated and it is quite obvious that this is why they cut the graph. Its not a bad thing, just an intelligent way of marketing their product if you ask me. a white lie maybe?? I believe google is your destiny my friend.
    Right on Chris!
    Very good example siting the vette;)
    They don't make the most bang for your buck in a vette by not knowing what their doing..
  11. Jan 14, 2009 at 7:16 PM
    sonjay
    I'm sorry if I came off as rude. I should have said please explain. I don't think there dyno results are comparable, as they are from different trucks, and probably on different dynos. There dyno might not record anything in that low a RPM? Why would the baseline for the stock truck also be cut off? I have owned a turbo car and it was very smooth and got good fuel economy if you kept your foot out of it. As for why chevy, a bankrupt company choose a blower, I would say because it would appeal to more of the consumers they hope will buy there car. Plus they would probably have a hell of a time cramming a turbo system in there! Why is it that diesel engines stopped using superchargers some 30+ years ago in favor of turbos? Why is it that Formula 1 race cars, the pinnacle of racing technology, up until a few years ago used turbochargers? Toyota, Nissan, Mazda, Ferrari, Mercedes Benz, Audi, VW have all produced Turbo cars over the years. I like super-chargers, they are great for certain applications, such as drag racing plus they sound bad ass. However a turbo IMO is much more efficient by design, it makes it's boost from wasted heat.
  12. Jan 14, 2009 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They have a very narrow operational rpm range. Big diesel engines have around 1000 rpm operating range, F1 cars stay above 8 to 10,000 rpm.
    Im not saying that turbos are usless, but SO many people have this ilusion that turbos are a "free" hp gain, when the fact is they are not. They are a restriction in the exhaust. Throw a turbo on your exhaust without hooking it into the air intake, and tell me you wouldnt feel a loss in power. Modern superchargers have about as much drain (parasitic drag) on an engine as the AC compressor and steering pump combined.
  13. Jan 14, 2009 at 8:08 PM
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    F1 cars don't use either power adder, and normally remain in the 14k-20k RPM band.
    http://www.youtube.com/watch?v=rp4SV8FGZoo
    One thing you learn with engineering. The is NO FREE POWER, EVER!. I don't care what kind of snake oil the guy is selling, you have to give something to get something.
    Also, turbo chargers leach oil from your engine, use it and add TONS of heat to it. Not to mention what happens when (not if) the turbo eats its bearings and starts pumping those bits back into the motor (right into the oil pan!!!)
    Supers are a self contained unit, if they fail, they just get inefficient. Its rare to see one where the rotors have actually been grinding on each other.
  14. Jan 14, 2009 at 8:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Right. We were talking about when they did use them. And I was unsure of their opperational RPM's, but I knew it was way up there. ;)
  15. Jan 14, 2009 at 8:56 PM
    afd23a
    The Dynamo of Dixie
    I don't know all of the pros and cons which is why I was curious what your reasons are. To me, since the SC is bolt on (somewhat I assume), designed by Toyota, and has a Toyota warranty, which all seem like pretty good reasons reasons to me. That does not take into account performance differences at all. If Toyota thought a turbo was a good idea, I'd think they would have offered one instead of a SC, but I don't have the experience/knowledge to say.
    The videos on STS's site are pretty cool, though. Toyota doesn't make a SC for my 4-banger, but STS does make a turbo.......
    I wasn't trying to start a debate... :deadhorse:...even though it was probably unavoidable.
  16. Jan 14, 2009 at 10:59 PM
    sonjay
    Personally I think the 4.0L has plenty of power, and I question the durability of the engine with either a turbo or SC? I like how the STS kit moves the turbo and the heat out of the engine compartment, and runs lower boost. Its also a bunch cheaper, and you can make more power without buying anything new. The TRD SC is pretty simple, it gives you a much better intake and its all made by Toyota. However with the SC to get the most out of it, you really should replace the headers and exhaust. In the end there doing the same thing.
  17. Jan 15, 2009 at 6:20 PM
    patrickockander
    Patrick
    San Antonio, TX
    what do you all think about having a supercharger AND a turbo? is it possible?
    might be the ultimate solution to this debate.....
    seriously...if it's possible, I might be willing to do it....
    thanks,
    Pat
  18. Jan 15, 2009 at 6:26 PM
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    Only problem with the STS is that it hangs underneath the truck, able to be hit by rocks and brush out on a trail
  19. Jan 15, 2009 at 6:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Detroit Diesel made a bunch of 2 stroke supercharged and turboed engines for farm and heavey construction equipment. They sounded MEAN! For a modern gasoline engine, I dont think its very practical.
  20. Jan 15, 2009 at 6:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2.
