turbo kit 3rz 2000 taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by TheTicosTaco, Sep 4, 2009.
  1. Sep 4, 2009 at 6:11 AM
    TheTicosTaco
    TheTicosTaco [OP] Member
    CenCal,
    4x4,3rz,lifted,intake,exz,campshell
    intake,exs,liftkit3",3rz,campershell,etc
  2. Sep 4, 2009 at 6:26 AM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    That is a crap turbo kit with nothing but knockoff parts. i wouldnt pay more then 500 bucks for it.
    You need to try to find a shop that specializes in turboing your car or build something from scratch. The only thing in that kit that LOOKS ok would be the exhaust manifold but that would be ONLY if you supported the turbo from another source.
    Edit: it is also nowhere NEAR complete.
  3. Sep 4, 2009 at 6:30 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Get an SC from Alpine. Its bolt on and go.
  4. Sep 4, 2009 at 1:41 PM
    spasur
    spasur Well-Known Member
    New Orleans
    02 PreRunner 4cyl
    what he said ^^^^
    turbos have the potential to be better than an SC, but the added complexity can make it much more difficult to achieve that potential. For most people who aren't willing to spend time constantly tweaking their setups, an SC is the way to go...just my opinion
  5. Sep 4, 2009 at 1:57 PM
    Mac2118
    Mac2118 Well-Known Member
    Pennsylvania
    01 Tacoma SR5
    it looks like an ebay setup to me.
  6. Sep 4, 2009 at 2:27 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    Yeah be careful your engine will eat that torbo for lunch, literally..
    Those Chinese turbos are not balanced to the specs necessary for 40,000 rpm operation, only a matter of time before it grenades....
    The manifold may work, make sure the wastegate clears the AC if you have it...
    Looks like it would be OK minus the turbo and the cheap wastegate.
    How much, I didnt check the link?
    OMG checked the price $1800!!!! No way...
    Too bad your not in So. Cal, I could build you a full intercooled setup..
  7. Sep 4, 2009 at 6:54 PM
    df4iguy
    Dan
    Chicago
    Just a good turbo should cost anywhere from 900 to 1500 depending on how big it is and if it's ball bearing
