turbo kit for 3rz 2000
Discussion in 'Performance and Tuning' started by TheTicosTaco, May 28, 2009.
  1. May 28, 2009 at 8:46 PM
    TheTicosTaco
    TheTicosTaco [OP] Member
    CenCal,
    4x4,3rz,lifted,intake,exz,campshell
    intake,exs,liftkit3",3rz,campershell,etc
    hey guys i thinking of turbo kit for my 3rz 2000 . 4x4 .. is it worth it .. and is not California smog a provable .. ??
    its a t3 ... .42 ar compressor .48 ar tubrine wet float bearing
    what u guys think .. is it worth it ???
    thanks
  2. May 28, 2009 at 8:48 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    check out KO racing amongst many others and find a good one for you
  3. May 28, 2009 at 9:15 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    There's ALOT more that "slapping a turbo" on the truck.
  4. May 28, 2009 at 9:24 PM
    TheTicosTaco
    CenCal,
    what i mean is .. puting a turbo on my toyota is wrth the money ima spend into it..
  5. May 28, 2009 at 9:25 PM
    dually
    dually Low and slow
    What are your goals? What are you looking to do with the truck? How much money are you willing to spend? Im almost 4k into my build....
  6. May 28, 2009 at 9:29 PM
    MiikeyD
    MiikeyD The Green Machine
    Upland, CA
    Green Prerunner DC 2.7L
    Suspension / Wheels / Tires 3.5" Fabtech lift w/ AAL 265/75/16 BFG A/T American Racing Baja Audio Alpine HU CDA-9886 Kicker DS650 Z-Edition 1000W Memphis M3 US Amps 4000W 2.5Farad Cap Lighting 6000K HID 2 Hella 500FF 2 Aux Bed Lights 2 Aux Driving Lights Performance Volant CAI Flomaster Super 44 Doug Thorley Long Tube headers (coming soon) NGK Iridium Sparkplugs Accessories Scanguage II Cobra LTD27-NW with 3' Firestik Radio Shack Triple Trunking Scanner Harbor Freight Hi-Lift Cosmetics Flat Black Bumper Trim Flat Black Grill Surrounding with Satoshi Clear Corners Future Modifications (not specific) Longtravel w/ king shocks or fox Caged bed Shackles rear suspension. Fox / king shocks custom front bumper Custom Glassworks extreme kit for 01-04 (only have hood and passenger side.. need driver panel) Supercharger + 8port intake manifold optima yellow top battery remounted new rims caged interior rear bench removal 4 sparc
    im thinking about putting a turbo on my 02 3rz also. i think it would be a good investment since it is only an i4 and i4s only push about 150 or around there. im not sure what the stock hp is. I want to get a turbo so I have more power to push my truck through steeper inclines and around in the sand. I guess it all depends on what you plan to do with your truck. like dually said it all depends on how much you want to drop into your truck.
  7. May 28, 2009 at 9:35 PM
    dually
    dually Low and slow
    Yes, and its a ton of work and a lot of commitment.
  8. May 28, 2009 at 9:36 PM
    TheTicosTaco
    CenCal,
    well for towing power i though it would help ,and for also 4 wheeling in the sand ... . well im lookin @ a turbo for $1700 . and shop like 1200.
    is it true @ 20.000 ima hav to get the turbo change or reconditioned .. ?
  9. May 28, 2009 at 9:42 PM
    dually
    dually Low and slow
    So just the turbo is 1700? There is a lot more than just the turbo, you have the manifold, upgraded fuel system, some sort of engine management system, internal upgrades, instruments and the list goes on...
    A turbo will be needed to be rebuilt whenever it goes out. hard to say when. You should really pick up the book "Maximum Boost" by Corky Bell, and read up on this subject.
  10. May 28, 2009 at 9:53 PM
    TheTicosTaco
    CenCal,
    aite for sure ima check it out @ borders .. thnks man i forgot about fuel up grades .. yea its for all @ tht price its blow off val , t3 and manifold turbo side mount and . intercool. and bolts nuts, alll thm goodies
  11. May 28, 2009 at 11:49 PM
    MiikeyD
    Upland, CA
    theres a dude selling a full turbo system for a 2rz/3rz on customtacos. there is a thread somewhere around here that was posted.. ill pst when i find
  12. May 29, 2009 at 9:32 PM
    98yota
    98yota Mean Green Machine
    Marion, VA
    4WD Timberland Mica taco
    CAI, gutted cat, bed cover.
    well, not exactly. i have chatted with people that run their 2/3rz's with 4-6 lbs of boost on stock ECU and fuel system...no problems at all. it's def. a good idea to have all that you listed, but for a low boost setup it will be fine. i have a friend from knoxville, tennessee with a 3rz turbo running 5 lbs that ran a 15.3 @ 89 mph. he popped the clutch off the line, all he did was spin. i think its easily a good mid 14 second truck. he stayed on the bumper of a nearly stock SRT-4 on the interstate from 40-~90...so i think thats pretty accurate. 2/3rz's love boost :D
  13. May 29, 2009 at 10:52 PM
    dually
    dually Low and slow
    Yes, you 'can' run stock fuel system, but would rather have the re-assurance you're getting enough fuel?
    And yes the rz motors LOVE boost, mine wants more!
  14. May 30, 2009 at 6:30 AM
    98yota
    Marion, VA
    yeah man, i def. agree that you need the re-assurance of having an upgraded fuel system. He has his cat gutted, so before he even put the turbo on there, it was already running a little rich b/c of that, so it worked out pretty good haha
  15. Jun 7, 2013 at 5:21 AM
    great southern la
    great southern la New Member
    Trent
    australia
    99 rzn169 hilux sr5
    turbo
    hi just wondering how you go running the stock ecu on the turboed 3rz? mine keeps stalling when it returns to idle??/??
  16. Jun 7, 2013 at 6:09 AM
    dually
    dually Low and slow
    It is an issue with the MAF and an overrich mixture. Where is your maf located? Are you recirculating your bov?
  17. Jun 7, 2013 at 7:32 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    A proper install, with proper parts will be worth it. There is one for sale here. It links back to Custom Tacos.
    Cheaping out will cost you extra. So beware.
  18. Jun 8, 2013 at 3:31 AM
    great southern la
    Trent
    australia
    99 rzn169 hilux sr5
    turbo
    I am not running a bov, only running 5psi boost the maf sensor is located between the air box and turbo.
  19. Jun 8, 2013 at 5:33 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    your truck automatic?
  20. Jun 8, 2013 at 6:57 AM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Can't turbo any n/a vehicle and get it to pass smog in California unless the vehicle came with some sort of factory turbo.
    Only way around it is to register your vehicle in a smog exempt area.
