turbo kit for 3rz 2000
Discussion in 'Performance and Tuning' started by TheTicosTaco, May 28, 2009.
  1. Jun 8, 2013 at 2:56 PM
    great southern la
    great southern la New Member
    Trent
    australia
    99 rzn169 hilux sr5
    turbo
    no its not auto its a 5 speed.
    don't have to worry about them smog laws in Australia mate ;-)
    I have ordered a greddy emanage blue but am waiting for it to arrive in the meantime I thought I might be able to get it running a bit better with the stock ecu but cant seem to find out how, I have found on the forums around the traps the same thing happening to other people, but no one has a solution except change ecu. thought you yanks might have an idea?
  2. Jun 8, 2013 at 4:36 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well, one problem per say, is that you have a manual, and no BOV. That will cause a pressure build up back to the turbo, every time you shift. Depending on how high the RPM, how much boost you are running, if you have a ported shroud, and how quickly you shift, you can cause some pretty severe compressor surge.
    That in itself will destroy a turbo.
    As for the MAF and over rich issue, need more info.
    EDIT**** Ok, need some pictures. Depending on what the tubing looks like where your MAF sensor is located, I think I know what the issue is. Post up a picture of the engine bay, and a one of the intake pre turbo.
  3. Jun 8, 2013 at 4:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Previous post edited
  4. Jun 12, 2013 at 5:52 AM
    colby8100
    colby8100 Well-Known Member
    Colby
    South carolin
    01 Tacoma 1jz lowered
    Lowered,leather interior,system,1jz swap,rims,painted bumpers mirrors ect
    I would advise running a bov. 5psi would probably not be enough pressure to set it off especially on an auto. But it that waste gate ever sticks there is a high possibility you will back spool the turbo.
