Turbo Kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Swimmerboy2112, Aug 27, 2013.
  1. Oct 29, 2014 at 3:23 AM
    #201
    Robb235
    Robb235 Well-Known Member
    Chattanooga, TN
    1999 Turbo 4Runner
    Turbo 5vz uaEFI Standalone ECU 231mm Tundra Brakes RR Diff Lock Hayden 699 Transmission Cooler
    Ok, I'll give them a call. Do you have any threads you can link me to that talks about their manifolds? It just seems if it were that easy to get turbo manifolds from them, more people would have done it already, as they have with CXRacing's. I'll check them out though.
    And who is 52eighty?
  2. Oct 29, 2014 at 6:50 AM
    #202
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    They do custom setups but it gets $$$. However, as Monte pointed out, def better quality. CXRacing quality is ok and nothing to be afraid of, but if you can afford it, check them out :thumbsup:
  3. Oct 29, 2014 at 7:44 AM
    #203
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Go twinz :cool:
    1997tacomav6 likes this.
  4. Oct 26, 2015 at 9:36 AM
    #204
    Tap1
    Tap1 Member
    Puerto Rico
    2011 Tacoma 2.7l
    Turbo
    2tr-fe turbo?
