turbo life span
Discussion in 'Performance and Tuning' started by vtragweed, Feb 24, 2009.
  1. Feb 24, 2009 at 3:56 PM
    vtragweed
    vtragweed [OP] Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    im thinking about getting a turbo system for my 2.7 anyone know what the average life is on a turbo?
  2. Feb 24, 2009 at 4:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As long as propper oil psi is maintaned to it, it should last a long time.
  3. Feb 24, 2009 at 6:53 PM
    Fredneck
    Fredneck Active Member
    Wyoming
    09 2.7L Tacoma
    BONE STOCK for now
    I've manged to Kill 3 differnt turbo's on my Diesel Dodge. All happened at high boost levels > 40 PSI. It's best to operate you turbo witin the compressor map. If you get to close or outside of the edge of the map the compressor enters the realm of stall or surge. Also a blowoff valve is a real good idea if you are running a lot of boost.
    If you keep the boost at sane levels and allow the turbo to cool down at idle after some hard running a turbo will last many many thosands of miles.
