turbo retro fit suggestions
Discussion in 'Performance and Tuning' started by SargeSlapnuts, Oct 6, 2011.
  1. Oct 6, 2011 at 2:17 PM
    SargeSlapnuts
    SargeSlapnuts [OP] SargeSlapnuts
    Nick
    Pooler, Ga
    2003 taco TRD off road 4x4 dbl cab.
    255/85-16 BF goodrich km3's, modified trail gear Bumpers front and rear, 10k winch, ranch rear lift shackles, Rancho coilovers in the front, grey wire mod, aftermarket stereo, camper top on the back.
    Well long story short i would like a small gain in performance outta my 2.7l taco. now before everyone trolls like hell i would like to say i want no more boost than 3-4psi out of a small turbo to assist with low end tourqe.
    i was also consdering a centrifugal blower on low boost. would like to be able to maintain stock ecu and all. i know the stock ecu can handle up to 6psi of boost. i dont want to go that high for reliability reasons.
    a remote turbo setup might be intersting as well
    thanks
  2. Oct 6, 2011 at 9:30 PM
    RenoTacoma
    RenoTacoma Petrol head
    Sloan
    Reno, nevada
    09 Base 4x4 Tacoma
    3.5" lift 285/70/17
    Ive been looking into a remote mount turbo running 5-6psi on my truck. Alot of parts are needed to be reliable and stable for the trucks engine. Its at least a grand to do it "right"
    your best bet is to go on xr underground, they are the turbo gurus
  3. Oct 6, 2011 at 10:41 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    Why not look into getting the TRD s/c for that motor. Not sure how easy they are to find these days. I had one on my 04 2.4 and it made a world of a difference. I bought mine from lc engineering.
  4. Oct 7, 2011 at 8:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I see a picture of your truck in some fairly deep water. For that reason, you don't want a rear mount turbo.
  5. Oct 7, 2011 at 9:14 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    A grand?? Hahahahahahahahaha!! maybe if you have all the material and a $200 junkyard turbo, a welder, and now how to build systems...
    To do it "right" it will take at least $2000, for a remote system just the oil scavenging pump is gonna be $300 alone! Then the turbo $600+, and EVERYTHING else. When I had my truck turboed just the turbo was $1300.
  6. Oct 7, 2011 at 9:42 AM
    Speed Freek
    More than a turbo, lol.A little under $5K for the drivetrain and all the other parts exhaust, header kit, etc...
    And about 2 months of work installing it. It is has about the same power as my old 2RZ turbo setup at 5000rpms, but the LS1 has more power everywhere else. Not to mention the 6 speed transmission!
    Best mod ever, I get to make other vehicles look stupid daily. The power and sound of a muscle car in my little taco, pretty cool.
  7. Oct 7, 2011 at 2:39 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    cause i got the truck for a quater of what its worth now. i like it and it suits me pretty well cause im still aware that im a 2wd so i dont bury the mother fucker left and right. . . . lol plus if i reall wanna go 4wd ill just find a wrecked truck and do the swap to keep insurance cost low :)
  8. Oct 7, 2011 at 8:20 PM
    SargeSlapnuts
    Nick
    Pooler, Ga
    i will when i come across a wrecked truck but im in no rush to do so,
  9. Oct 7, 2011 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
