Turbo taco truck on the dyno
Discussion in 'Tacoma Videos' started by kickergt, Jan 12, 2013.
  1. Dec 19, 2013 at 2:17 PM
    #41
    TheGoat
    TheGoat Well-Known Member
    Justin
    Greenville, SC
    White 07 SR5 4x4 6spd & Silver 06 SR5 4Runner
    OME 885 springs on 90000 shocks, sway bar removed and 1.5" AAL
    Turbo Taco! yum!
    I miss turbo, the sounds...and the transition from lag to boost. :(
  2. Dec 19, 2013 at 9:11 PM
    #42
    DSMJRV
    DSMJRV Well-Known Member
    justin
    Corona, CA
    The FMU is not like the 7th injector, it just increases fuel pressure. Regardless, the stock injectors can still only flow so much.. Yes the SAFC is for tuning but only within the limits of the fuel system it is attached to.. An upgraded fuel pump and increased fuel pressure on stock injectors doesn't seem like enough to support an extra 100whp is all i was saying..
    orly? It does not matter what you do to the fuel system, everything is still bottle necked at the injectors, they have the final say... so yes assuming that what he listed as fuel mods is all he actually has, that is essentially a stock fuel set up..
  3. Dec 19, 2013 at 9:29 PM
    #43
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    Injector flow is based on fuel pressure. If you tell someone all they need is bigger injectors, but don't tell them to upgrade their fuel pump, the fuel pump will not be able to keep up with higher fuel flow - and you will run lean (not only will you run lean, but you'll run lean at the worst possible time - when you need more fuel because you're in boost). A fuel pump is absolutely considered a fuel modification. Modifying fuel pressure and increasing fuel delivery is not how the truck rolled off the assembly line.
    My car has 42psi base fuel pressure. Increasing to 50psi provides a 9% increase in injector flow. Taking fuel system that can barely handle 220whp and increasing fuel capability by 50% doesn't seem reasonable to do just by bumping fuel pressure - I agree. However, increasing fuel pressure and running a higher flow pump is NOT stock. I do not see how you can possibly argue this.
    I definitely don't know everything, but I built and tuned the MR2 in my garage - forged motor, 1200cc injectors, standalone EMS and a GT3071 running about 23psi on E85. I'm not exactly clueless here.
