Turbo timer for supercharger?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by huj2000, Nov 6, 2015.
  1. Nov 6, 2015 at 5:14 PM
    huj2000
    huj2000 [OP] Well-Known Member
    dan
    Burbank, il
    2010 Tacoma Offroad 4.0 V6
    Supercharger
    Has anyone made or know of something like a turbo timer but for the trd sc im interested in doing something like this so the coolant pump and possibly the engine fan to run for a bit maybe on a timer or to run off a temp sensor in the manifold
  2. Nov 6, 2015 at 5:37 PM
    muisejt
    muisejt Well-Known Member
    YMM
    08 TRD Sport DC LB
    Katzkin, Bi-xenon Morimoto Mini Stage III Kit (D2S), 4Runner Mirrors, Complete Stereo Upgrade with Backup Camera, Pop&Lock PL5400, Extang Solid Fold Tonneau, TRD OR Tow Hook, rcbs204 4x4 Illuminated Switch, Grillcraft, 10" Rigid light bar behind grill, relocated horns, Redline Tuning hood struts, 5100's with 883 and Wheeler 5 leaf, OME carrier barring drop kit, ECGS Bushing, MarionB2B front hubs
    unless you just ran the Indy 500 and shut your truck off as soon as you crossed the finish line I don't think you need it. a turbo timer keeps the oil pump going so the oil doesn't burn up and clog the lines, a turbo runs a lot hotter than a supercharger
    Lord Helmet and jmaack like this.
  3. Nov 16, 2015 at 12:34 PM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    oilcooled turbocharger bearing gets very hot because its a small diameter bearing and gets heat from the exhaust side of the turbo. Timer is to keep oil flowing after exhaust stops, so as to prevent oil from 'coking' in the hi heat remaining from the exhaust side with no oil circulation. Tacoma Supercharger would not have that kind of challenge.
  4. Nov 16, 2015 at 1:07 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Useless for a supercharged engine, and nearly useless for a turbocharged engine. Just drive like a normal person for the last couple minutes of your trip and the turbo will cool back down to normal operating temp. Turbo timers are just a waste of fuel.
