Turbo vs Supercharger
Discussion in 'Performance and Tuning' started by beastlytaco, Oct 16, 2008.
Which one: turbo or S/C
  1. Turbo
    325 vote(s)
    28.2%
  2. Supercharger
    656 vote(s)
    56.9%
  3. Dont spend the money on either
    171 vote(s)
    14.8%
  1. Sep 4, 2009 at 12:03 PM
    #181
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    This has already been said in earlier posts, but Turbo chargers aren't able to produce boost like superchargers in the lower RPM range. If you're offroading, that is generally where there is the greatest need for increased power. If you have to rev your engine to 2500-3000 before you see any significant boost than you've gained no advantage for offroading unless of course you plan to just blast through everything as fast as you can. :laugh:
  2. Sep 4, 2009 at 12:58 PM
    #182
    ElectronMan
    ElectronMan Well-Known Member
    But with a lot of serious off road rigs with nice transfer cases, you are talking effective gear ratios in the 130:1 to 100:1 range. In those ranges your spinning the engine well past 3000 rpm and your supercharger can't keep up with your demands. All I'm saying is, it's not as simple as on-road, off-road, racing, etc. The decision should be heavily weighted on your goals and intended uses.
  3. Sep 4, 2009 at 2:07 PM
    #183
    drew02a
    San Antonio, TX
    At the point where you have that low of a creeper gear, the power added by a supercharger/ turbocharger is irrelevant.
  4. Sep 4, 2009 at 9:28 PM
    #184
    cullensheffiled
    cullensheffiled Active Member
    cullen
    georgia
    05 trd
    3 inch ome lift kit k & n air intake 33 inch pro come all terrain tires 17 inch helo rims jvc bongovi headunit 2 stage 3 rockford fosgates and 2000 watt rockford fosgat amp
    trd s/c would be the best one?
  5. Sep 5, 2009 at 7:10 AM
    #185
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    well with a turbo your gonna have to run premium and witha S/C your gonna have to run premium. and it all depends on your driving style. since the turbo goes off of exhaust from the headers, its gonna depend on how high your rpms are gonna be for that thing to kick in. but if like you said your gonna be doing trails, and hauling i would get a S/C jsut for the shear fact that you have less delay witha S/C than a turbo. turbo is for mainly applications where high rpms are going to benefit you. S/C is for aplications that you need power all throughout the rpms.
  6. Sep 5, 2009 at 7:12 AM
    #186
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
  7. Sep 5, 2009 at 7:17 PM
    #187
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah, its only because you can cover the TRD one under warranty. after market ones you cant like the TRD one. IMO id go with something elese other than the TRD. Rotrex makes a good one
  8. Oct 5, 2009 at 7:55 PM
    #188
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    how necessary is it for 91 octane with the sc will you get pinging without
  9. Oct 5, 2009 at 8:14 PM
    #189
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  10. Oct 13, 2009 at 12:10 PM
    #190
    98tacoma27
    Ben
    Not Beech Creek
    What he said.
  11. Oct 13, 2009 at 10:22 PM
    #191
    Quadcams
    Quadcams Member
    Sydney, Australia
    Hilux 4.0l v6 4x4
    For the street a s/c win hands down, way more practical, more linier power curve, bigger power band. Turbos have a too aggressive torque curve, run some decent boost and its wheelspin city everytime you give stick, yes you can make more good power with a turbo, but good power in my eyes is power you can use.
  12. Oct 13, 2009 at 10:31 PM
    #192
    Quadcams
    Quadcams Member
    Sydney, Australia
    Hilux 4.0l v6 4x4
    Seeing the TRD s/c is a Twin screw type s/c, where the say URD s/c is a centrifugal s/c (like a turbo), the TRD kit in my eyes is a much more practical choice for the street as it comes onto full boost much quicker, 1500-2500rpm, where the centrifugal type doesnt reach full boost till readline, much more torque down low with the TRD, which is where you are most of the time driving.
  13. Oct 21, 2009 at 11:08 AM
    #193
    blkcoma32
    blkcoma32 Well-Known Member
    Illinois
    98' 4x4 on tirty trees
    3 inch coilover and add-a leaf lift
    i voted supercarged for simplicity of install but i love turbos if u want to spend the time and money!
  14. Oct 31, 2009 at 9:44 PM
    #194
    gcwaterski
    gcwaterski Well-Known Member
    What is the CHEAPEST FI kit for our trucks?
  15. Nov 1, 2009 at 5:38 PM
    #195
    gcwaterski
    A) So there is currently not a turn key turbo kit for our trucks, right?
    B) But a turbo kit would be cheaper than a S/C kit?
    C) And the TRD kit is the cheapest S/C kit out there, right?
    D) But someone is working on a turbo kit to be offered?
  16. Nov 1, 2009 at 6:02 PM
    #196
    ktmrider
    Junk
    what does that mean i so dont understand:confused:
  17. Nov 1, 2009 at 6:05 PM
    #197
    gcwaterski
    yeah, a lil vague
  18. Nov 1, 2009 at 7:48 PM
    #198
    gcwaterski
  19. Nov 2, 2009 at 4:31 PM
    #199
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    A - STS makes a remote-mount turbo kit, i wouldn't call it turn key, but it is a bolt on with everything you need (and you'll be lucky if you don't need to spend more time and money to get it working right)
    B - Turbo would cost more then a S/C kit if done right
    C - TRD S/C is the most affordable (and currently the fastest s/c in the 1/4 mile - both ET and MPH)
    D - Two shops are potentially working on a bolt-on front mount kits
  20. Nov 2, 2009 at 6:27 PM
    #200
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    Consider the tuning options you have then go from there. This is the factor that will make or break your build. If you have cash to blow, go stand alone.
