Turbo vs Supercharger
Discussion in 'Performance and Tuning' started by beastlytaco, Oct 16, 2008.
Which one: turbo or S/C
  1. Turbo
    325 vote(s)
    28.2%
  2. Supercharger
    656 vote(s)
    56.9%
  3. Dont spend the money on either
    171 vote(s)
    14.8%
  1. Nov 3, 2009 at 6:19 AM
    #201
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Just curious....has anyone ever talked to Garrett about a bolt in place turbo with all the plumbing?:rolleyes:
  2. Nov 3, 2009 at 3:38 PM
    #202
    gcwaterski
    gcwaterski Well-Known Member
    Thankyou thankyou!
  3. Nov 29, 2009 at 4:30 AM
    #203
    Krusey1011
    Krusey1011 Well-Known Member
    Kyle
    Washington
    Some damn good posts on this thread! :popcorn: Many props going to Chris as always lol
    I was going to get my lift kit first. But ever since I got smoked off the line at a redlight ( by a chrysler 300 I think) I'm getting the S/C first. I'm so ashamed! :facepalm:
    Now to decide between the TRD or the URD. IDK I got to look more in to it. Good luck to the OP on savin up the cash. I'm in the same boat. should be a couple of months. :yay::burnrubber:
  4. Nov 29, 2009 at 7:57 AM
    #204
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    Go all out on URD! LOL
  5. Nov 29, 2009 at 10:55 AM
    #205
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    the dont have any rotrex kits out for the 2TR-FE do they?
  6. Nov 29, 2009 at 1:43 PM
    #206
    Krusey1011
    Kyle
    Washington
    Yup! pretty expensive though. But my experience with URD so far has been great. That still doesn't change the price. lol They do offer discounts and work with you as much as possible. I get a military discount.:D IDK how much better the rotex is than TRD's though. Still slowly lookin into it.
  7. Nov 29, 2009 at 1:44 PM
    #207
    Krusey1011
    Kyle
    Washington
  8. Dec 3, 2009 at 8:37 PM
    #208
    edmondTrucott
    edmondTrucott Take what u can Give nuthing back!
    Edmond
    Sherwood Park Alberta
    2008 v6 4x4 dbl cab
    sts kits i have seen rape the trd supercharger kit how ever the trade off is the price 6500 for the sts turbo kit 2008 as i have looked in to the sts for my truck but with shiping it was way to much to get it to alberta o well it comes down to what you want under your hood braging rights?.... the 2 will add hp no dout there just pick 1 and enjoy ;)
  9. Dec 4, 2009 at 1:43 AM
    #209
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Super Charger FTW :thumbsup:
  10. Dec 13, 2009 at 8:40 AM
    #210
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    If you want to be fast off the line then you want to go TRD. Same if you want that massive amount of low end torque.
  11. Dec 13, 2009 at 2:31 PM
    #211
    Krusey1011
    Kyle
    Washington
    Yeah? I'm still unsure about it. I'm always wanting the best. URD seems to win there but I also won't be using my truck on the track. Street n offroad. So, still pretty torn. If TRD does seem to be the best street option and I can get as long of a life out of it as URD. Then with that and the price difference it'll be TRD FTW fo sho!
  12. Dec 14, 2009 at 3:44 AM
    #212
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Its hard to say which kit is the "best". Each kit has its pros/cons.
    For me, the TRD is a better choice then the URD. Plus I'm not a fan of centrifugal s/c. Positive displacement FTW!
  13. Feb 23, 2010 at 9:11 AM
    #213
    Taco505
    Taco505 Well-Known Member
    Alex
    New Mexico
    2011 4cyl 4x4 5 speed
    OME 884's/90021, MD Dakar/Nitrocharger.
    well i was thinking about doing this along time ago and saving for it. i was trying to make the same decision and i realized that.
    1. you can get much more power out of a turbo and tune it to the way you like it.
    2. when i was looking around no one had a kit for the 2nd gen 4 cily tacos it would most likely have to be a custom build.
    3. that could be more expensive or even less expensive than a S/C kit.
    4. the S/C will give you lower end power but not much higher end.
    5. i think S/C sounds alot cooler haha
    6. last one i promise if you can figure out how to put a twin turbo in that 4 banger you would be an effin rocket! and get rid of that turbo lag have one spool up at the low end and have the other kick in right after the first one :D
    but its a hard decision hope it works out for you!
  14. Feb 23, 2010 at 10:35 AM
    #214
    rme
    Savannah
    Green TACOMA
    If you get one for your 4 banger please post the results.....
  15. Mar 29, 2010 at 4:42 PM
    #215
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    Turbo if you have the money, blood, sweat and tears to put into it.
    I had a 2003 Lexus IS300. I ran the pro lex performace super charger kit. I installed it myself and went through a lot with it. I also had a lot of friends running turbo kits from several different places--From the basic SRT kit to guys who were running full GTE block swaps making 700hp+. Here is the very basic break down from my experiences.
    Turbos make more power with little to no parasitic losses. A super charger uses a belt and engine power to drive the compressor. A turbo uses waste exhaust gasses. At 7 PSI I dynoed at 305 RWHP on my IS. This was with a bigger injector setup and very very expensive tuning. The turbo kits running the same amount of boost were making about the same, But if you examine the torque curve you see that I was making about 265 lb/ft while the turbo guys were making over 300 lb/ft. The other benefit of turbo is that once you get into boost and the turbo is spooled up you make close to your max power till red line. With a super charger you build slowly. the amount of boost is dependent on the RPMs of the engine. So you really only make your max HP/TQ at redline. The other benefit to turbo is the ability to adjust the boost on the fly. This means you can run a mild tune at 7psi for daily driving and hit a button and be at 14psi when needed. The benefits of a supercharger is that you have the benefits off the line. as soon as you step on the gas and the engine revs you have boost. No turbo lag. The main reason to go with super charger for the tacoma is because of the availability of kits. The TRD kit was designed specifically by the Toyota for the engine and with proper installation can be fairly problem free. Where as with turbos, even ones designed for the car, can require a lot more work. I generally tell people who plan to take on a N/A - T conversion to set aside $2-4K more than they budget for misc things and problems. Plan on fitment issues, fuel system issues, ECU problems, and money for a reputable tuner. There are a lot of hack tuners out there that even others think are good. I had mine tuned by 2 different "good" tuners and still was running like shit. I finally took the car to a guy who tuned ferraris and built Nobles and Audi rally cars. Watching him was great. You could tell immediately the difference between a his abilities and the others. Getting a turbo setup running right will be a ton of work and money, but once running right, with the right transmission mods it will blow the doors off the SCs.
    my $0.02
    PS: Believe me, if I had an XR and didn't live in the smog nazi state I would be running a turbo by next year.
  16. Mar 29, 2010 at 6:30 PM
    #216
    rme
    Savannah
    Green TACOMA
    Excellent write up. I can understand this and people who I have blogged with this in this forum know an anvil can be smarter than me....Thanks for the clarity....:bowdown:
  17. Mar 29, 2010 at 7:11 PM
    #217
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Without a doubt supercharger.
  18. Mar 30, 2010 at 1:50 PM
    #218
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    for the price of the toyota supercharger and the power (or lack there of) that it makes it not worth it. I vote turbo all the way, best dollar per horse/ torque your going to find. For the price of the oem supercharger you can have someone built you custom headers, uppipe, downpipe, turbo manifold, hook up a intercooler and tap everything for oil coolant. And you will see wayyy more power
    This is all coming from a wrx guy btw
  19. Apr 1, 2010 at 5:59 PM
    #219
    replica9000
    replica9000 Death to AI!
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Well the TRD SC kit comes with a good amount for the price.
    -supercharger, intercooler (Low Temp Radiator), intercooler pump, fuel injectors, fuel pump, spark plugs, tensioner, and all the nuts, bolts, pulleys, belts, brackets, hoses, spacers. Even some fancy stickers to show off! And all warrantied in case it blows itself up. Most kits I've looked at for others cars cost about the same for just the basic charger and bolts to install it.
  20. Apr 1, 2010 at 6:29 PM
    #220
    rme
    Savannah
    Green TACOMA
    Can anyone tell me who makes a turbo charger for the TACOMA?:eek:
