Turbo vs Supercharger
Discussion in 'Performance and Tuning' started by beastlytaco, Oct 16, 2008.
Which one: turbo or S/C
  1. Turbo
    325 vote(s)
    28.2%
  2. Supercharger
    656 vote(s)
    56.9%
  3. Dont spend the money on either
    171 vote(s)
    14.8%
  1. Apr 1, 2010 at 6:32 PM
    #221
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  2. Apr 5, 2010 at 1:03 PM
    #222
    Idrivetoys
    Idrivetoys Well-Known Member
    Yuma AZ
    I need a 4 door DC 4x4
    either way you will have fun
  3. Apr 22, 2010 at 7:23 PM
    #223
    Dan893
    Dan893 Well-Known Member
    Dan
    Connecticut
    09 SR5 doublecab longbed
    TRD cold air intake, 6k HID headlights, 3K HID foglights, custom sockmonkey decals
    yes a turbo setup will get you more power easier but good luck keeping your truck reliable. You can get 330rwhp out of the supercharger relativly easily with the same mods you would have to do to a turbo setup minus the overdrive pully
  4. Apr 22, 2010 at 7:28 PM
    #224
    Dan893
    Dan
    Connecticut
    Those numbers where for a v6 though 4cyl I would go turbo so you can reach those kinda numbers hands down
  5. Apr 23, 2010 at 4:44 AM
    #225
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    Just asking...don't want to offend anyone but can you exlpain "keeping your truck reliable?" Are you saying not to do a turbo or to use a factory turbo?:confused:
  6. Apr 23, 2010 at 5:39 AM
    #226
    newengland
    newengland small /= slow
    NH
    07 Reg. Cab. 2.7L s/c
    Alpine Supercharger, DT header, Gibson exhaust, URD short-shifter, Hellwig anti-sway bar, backwards helper-leaf traction mod
    Custom turbo setups seem to need a lot of TLC to keep working. Supercharger kits won't break as much (from what I understand).
  7. Apr 30, 2010 at 5:30 PM
    #227
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    If you build a turbo system right it'll last thousands and thousands of miles
  8. May 14, 2010 at 10:03 AM
    #228
    Taco GTR
    Taco GTR Valdosta State University
    Orrin
    Shadydale/ Valdosta
    2003 Tacoma reg cab.
    Bone ass stock, 2nd air filter delete, JVC head unit, Alpine 600watt amp, JVC 1600 watt 12'' sub, Tractor Supply Company Toolbox, ALOT MORE TO COME.
    with a 4cyl go with a turbo because you can make more power and its less strain on the engine(hence the motor spining the supercharger). but if you have the money, go with 1or 2JZ power. cause that would be awesome turbo all the way
  9. May 14, 2010 at 12:31 PM
    #229
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    I mentioned before that i suggest turbo, but I think i need to elaborate a bit. If you are 4x4 then I would definitely chose supercharger over turbo. Because, with the turbo you will have to rev up to get the turbo to spool and get any benefit from it. So if you're moving slowly in 4x4 or stuck then the turbo will be of no help.
  10. May 14, 2010 at 3:27 PM
    #230
    rme
    Savannah
    Green TACOMA
    What is this or what does this mean? (Sorry for being such a dodo!)
  11. May 14, 2010 at 8:34 PM
    #231
    tacomakid89
    tacomakid89 Awesome Member
    William
    Austin, Texas
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime, King coilovers with remote resi in front, Kings with remote resi in rear, Deaver J66 leaf packs, TC UCAs up front.
    I hope to one day get a super charger on mine.
  12. May 14, 2010 at 9:46 PM
    #232
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    1jz and 2jz are supra engines.
  13. May 15, 2010 at 7:38 AM
    #233
    rme
    Savannah
    Green TACOMA
    I just hope to get a new Taco one day...my 95 is getting kind of old but it just won't quit....
  14. May 23, 2010 at 8:28 PM
    #234
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    ok so is there even a engine swap out there for our trucks..i mean like i know guys have taken older models and put lexus engines in them..but has anybody done anything recently with the 2TR-FE?
  15. May 23, 2010 at 9:04 PM
    #235
    dually
    dually Low and slow
    Be the first! RB swap?? 1300hp!!! 24valve cummins? :D
  16. May 24, 2010 at 10:16 AM
    #236
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Not true, it depends on how the kit or one off install was engineered, I have over 30,000 miles on a kit I built myself and I have been pushing 16-18psi every day and no problems once I got the engine management worked out (standalone)
    So an SC is easier, but a turbo will work fine too, as long as it is sized properly, and more importantly the system is built well.
    BTW Toyota had a turbo 4x4 (in the 80's), so they can work just fine...
  17. Jun 1, 2010 at 10:25 AM
    #237
    RYNO
    RYNO Well-Known Member
    Houston,TX
    for a truck, my vote goes to supercharged. Turbo for a car.
  18. Jun 1, 2010 at 2:39 PM
    #238
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    I vote turbo. I would want it to make full boost at 3500ish rpms. I don't need all the power down low when 4 wheeling with my 4clyd. What I do need is more power when passing or going up mountain passes. I think the tuning and power curve of a turbo would be better for me.
  19. Jun 14, 2010 at 11:19 PM
    #239
    quackhead03
    quackhead03 Active Member
    cody
    03 ex. cab
    K&N filter flowmaster exaust w/ chrome tip
  20. Jun 18, 2010 at 2:11 AM
    #240
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    My .02 cents.
    The exhaust on a gas powered turbo is a nightmare. had one once, pain in the ass. Lots of power though. Too much heat in the wrong places. I good idea gone bad. Unless it's intercooled forget reliability. A SC on the other hand is simple easy and it works.
    Maybe not as well but the amount of tweaking it will take to get the turbo in the same spot will be expensive and problematic.
