Turbo vs Supercharger
Discussion in 'Performance and Tuning' started by beastlytaco, Oct 16, 2008.
Which one: turbo or S/C
  1. Turbo
    325 vote(s)
    28.2%
  2. Supercharger
    656 vote(s)
    56.9%
  3. Dont spend the money on either
    171 vote(s)
    14.8%
  1. Aug 4, 2010 at 6:08 AM
    #261
    rme
    rme Well-Known Member
    Savannah
    Green TACOMA
    XM, Panasonic Stereo, Headlights,Electric Ant,Toyota Deluxe Wheels, Rhino Lining, Cargo Rails
    In Normal driving would it be your "opinion" your mpg would be better (no matter how slight) with a turbo charger vs a sc? I have a vw diesel and I gotta tell you I love my turbo charger as it seems easier to modify with parts already in place....
  2. Aug 5, 2010 at 9:52 PM
    #262
    Taco GTR
    Taco GTR Valdosta State University
    Orrin
    Shadydale/ Valdosta
    2003 Tacoma reg cab.
    Bone ass stock, 2nd air filter delete, JVC head unit, Alpine 600watt amp, JVC 1600 watt 12'' sub, Tractor Supply Company Toolbox, ALOT MORE TO COME.
    well thats the thing about a turbo compared to a sc. with a turbo you have to ride under boost. with a sc you are always boosting. but riding under boost get annoying when tryin to save gas. so in that section i give it to the sc. for power i give it to turbo. cause i mean once you have the sc. your kinda stuck with the mpgs you get. with turbo its a throw up.
  3. Aug 6, 2010 at 8:13 AM
    #263
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    You're not always in boost with a SC...
  4. Aug 6, 2010 at 10:02 AM
    #264
    Taco GTR
    Orrin
    Shadydale/ Valdosta
    yeah but its always pulling tho. thats what i was saying.
  5. Aug 17, 2010 at 4:54 PM
    #265
    ffblaze911
    ffblaze911 Well-Known Member
    Frederick, Colorado
    TRD OFF ROAD
    Supercharger
    so has anyone tested both on a tacoma?
  6. Aug 19, 2010 at 7:28 PM
    #266
    DanS
    DanS Member
    Central Coast, California
    Lifted 2000 Tacoma 4x4 5spd 2.7L 4cyl
    All-Pro upper A arms uniball long travel, tru trac rear locker, downy adjustable lift up front, all-pro rear springs 3 inch, greasable rear shackles from northwest offroad, k&n air filter, 33" BFgoodrich MudTerrain T/A, alpine stereo w/ipod hookup
    I don't know if saying the turbo is as robbing of power as a s/c because it restricts exhaust flow is a valid argument because a turbine extracts most of its energy thermally. A turbo WOULD create a restriction in exhaust flow, but it would be insignificant compared to the increased rotating mass added by a s/c. A turbines rate of work output is a function of the change in temperature of the fluid flow. exhaust expands across the turbine, allowing the turbine to extract thermal energy. I'm just stating what I've recently learned in a thermodynamics class...
  7. Aug 20, 2010 at 7:21 AM
    #267
    rme
    Savannah
    Green TACOMA
    You sure are smart...I can't even spell thermodywhatmacallit....but it does my old bones good to see smart people are putting into english how alot of this stuff works....what surprises me--I understood everything you said and that's "scary!"
  8. Aug 20, 2010 at 7:25 AM
    #268
    dually
    dually Low and slow
    All i know.. blown seals in my turbo tacoma suck!
  9. Aug 20, 2010 at 9:47 AM
    #269
    rme
    Savannah
    Green TACOMA
    What turbo you running and how long did it last. What year Taco you got?
  10. Aug 21, 2010 at 8:54 AM
    #270
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Like I already said, go ahead and change your pulley, but at a certain point your making enough heat that the extra boost does nothing good.
    Not to mention your still very limited in the power your going to make, I can run 10 to 23psi efficiently, can you? No.
    Like I said apples to oranges, SC if you want to bolt on a little kik and be done, turbo if you have skills and want to get far more power, but the SC is for most people since the parts are available and it bolts on in a few hours, turbo is not going to be that easy, so thats the dealbreaker for most people.
    OK rant over, just have to set some things straight, this is a great example of someone who has no or very little experience with turbos feeding hungry minds, misrepresenting turbos, I am just hearing the same thing from other people that dont know either, its not your fault.
    Its easy to repeat what you have heard, its easy to become misinformed as we see in this case. I see it all the time. There are some good books out there that can set things straight.
  11. Aug 25, 2010 at 7:52 PM
    #271
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    S/C = you need power to make power.
    Turbo = you can gain at least 50% more power.
  12. Aug 26, 2010 at 5:16 AM
    #272
    dually
    dually Low and slow
    SpeedFreek wins
  13. Oct 15, 2010 at 9:31 PM
    #273
    mikeyreolegio
    mikeyreolegio Member
    Michael
    Corona
    97 Tacoma LX
    thats such a vague comparison.
    you compared subaru, audi/vw, mazda, mitsubishi, etc. they all have turbos not superchargers?
    then you say that Subaru's STI and Mitsubishi's Evo choose to use a turbo instead of a supercharger.
    then you say that TRD offers a SuperCharged TC.
    So you really aren't contradicting yourself. You are just comparing the incorrect Make and Models.
    TRD is Toyota Racing Development
    Scion makes the TC
    to my knowledge Toyota, Scion, and Lexus are all under the same ownership.
    "I'm not an mechinical engineer, nor due it pretend to be"
    im in that same boat man. haha...
  14. Oct 15, 2010 at 10:21 PM
    #274
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    If I remember correctly, the tC was originally supposed to be turbocharged, which is probably how the car got it's name after Volvo complained about the use of the xC name. I know Eaton makes the TRD Supercharger for our trucks.
    Comparing a SC vs TC in this thread should be for our engines only. I would think bringing different cars/engines would each have their unique behaviors making a comparison of which is better not so easy. One engine might work better with a SC and maybe another engine work better with a TC.
    I also wonder if there are people that prefer a Turbocharger more cuz of the feeling when the boost kicks in as where superchargers have a more steady pull.
  15. Oct 16, 2010 at 9:55 AM
    #275
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    just give it the hennessy treatment....twin turbos + supercharger.
  16. Oct 17, 2010 at 3:12 PM
    #276
    Series1000
    Series1000 Well-Known Member
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    Lots
    Look around, s/c is more user friendly than a turbo. I have run turbos stock and modded, and I have installed and driven built cars with s/c's.
    It comes down to how much power you want to make and how much you want to spend to get that power.
    Its up to the Op what he wants to do, each has a strict following and they as you can tell get "passionate" about their own kind of "boosting"
  17. Oct 17, 2010 at 6:50 PM
    #277
    sloancallaway
    sloancallaway Well-Known Member
    Sloan
    Spruce Grove Alberta Canada
    Ive heard of a twin charge set up, but a tri-charge, now thats interesting, I think I would keep that one on road though
  18. Oct 17, 2010 at 8:53 PM
    #278
    tt07
    tt07 Well-Known Member
    north carolina
    01 4wd
    none yet
    s/c all the way!!!!
  19. Oct 17, 2010 at 9:03 PM
    #279
    blackwidow2009
    blackwidow2009 Well-Known Member
    Brian
    Cleveland
    09 Access Cab 4X4 TRD w/ SR5
    2.5" front lift Daystar coilover spacer. 2.5" rear lift add-a-leaf N-Fab wheel to wheel nerf/step bar Polished Stainless Leer cap from my 2000 Tacoma --- It does fit; don't let them lie to you
    Well, first you need to ask your self what you want it for....street or track.
    For the track TURBO; because it will perform better on the track. there is a thing called "turbo lag"....you press on the gas a go like normal, but after a second or two (once your building speed up) the turbo kicks in and you go like hell. This is better for the track because you wont spin your wheels, losing valuable time.
    Street...supercharger...instant GO, but that is ok because your already moving and not at a stand still like on a 1/4 mile track, your just want that kick to blow by someone when needed.
    My vote is for supercharger.;
    just noticed this post was originally posted about 2 years ago...you probably already got what you needed lol
  20. Oct 18, 2010 at 10:49 AM
    #280
    mikeyreolegio
    Michael
    Corona
    97 Tacoma LX
    id go for a turbo in my tacoma. i just love the sound of a blow off valve
