Turbo vs Supercharger
Discussion in 'Performance and Tuning' started by beastlytaco, Oct 16, 2008.
Which one: turbo or S/C
  1. Turbo
    325 vote(s)
    28.2%
  2. Supercharger
    656 vote(s)
    56.9%
  3. Dont spend the money on either
    171 vote(s)
    14.8%
  1. Dec 12, 2013 at 11:31 AM
    #461
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Turbo!
  2. Dec 12, 2013 at 12:41 PM
    #462
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    You get the URD injector kit yet?
    :cool:
  3. Dec 12, 2013 at 2:39 PM
    #463
    subwayaz
    subwayaz Well-Known Member
    Tucson,Az
    2012 Accesscab; TRD
    Super Charger, Catback Exhaust,Side Wind Shades, & Carbon Fiber Dash Kit
    For a Truck like our Tacoma's I suggest a Super Charger due to the point that most often I want the power all through the Powerband. Turbo won't do that; it takes a certain RPM range to get your Boost.
    And I have the TRD Super Charger by the way and Love it. I tow trailers with my truck quite often and find it to be such a help.
  4. Dec 12, 2013 at 2:58 PM
    #464
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What about the F150 twin turbo EcoBoost?
  5. Dec 12, 2013 at 3:32 PM
    #465
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    From what I read, a T4 gives positive boost at 2k rpms. If you want instant boost, a T3/T4 or even a T3 would give plenty low end boost. I don't like the SC due to the in-efficiency and lack of intercooler. Besides, the CXRacing kit is ~$1000 cheaper than a new TRD S/C.
    From http://www.samsonfab.com/phpbb2/viewtopic.php?t=34
  6. Dec 13, 2013 at 10:12 AM
    #466
    Large
    Large Red
    :popcorn:
    I love mine btw :anonymous:
  7. Dec 13, 2013 at 4:40 PM
    #467
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    or just swap a d4d in there with donor eca, upgrade the turbo, do some tunining and have one sick motor: )
  8. Dec 13, 2013 at 6:07 PM
    #468
    Darthyota
    Darthyota Well-Known Member
    Alberta
    Blown BSP X-Runner
    TRD s/c @ 9lbs, Unobtanium Welding 321SS Full Race Exhaust, B&M s/s, TRD 1st Gen CAI, sittin sic track ready drop, TSW Tanka's with 275/40/18's all the way around, 4300k hid's in headlights and fogs, with more to come
    Oh to have 30000 for a high output d4d swap
  9. Dec 20, 2013 at 7:06 PM
    #469
    TPain
    TPain Boss
    Tanner
    Asheville, NC
    01 Supercharged
    no
  10. Dec 23, 2013 at 10:52 AM
    #470
    JLee50
    JLee50 Well-Known Member
    Phoenix
    Stockish 99 4x4 TRD
    ToyTec coilovers
    The CX Racing kit doesn't come with fuel management, and with the power you can put out with a GT35 turbo you should definitely have more than a 7th injector setup.
    I really want to find an OBDII compliant piggyback that's easy to work with...I'd consider going standalone, but I need OBDII for emissions. :(
  11. Dec 23, 2013 at 2:38 PM
    #471
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    For once some TW peeps with brains on there shoulders, well for the most part. The swap is only about 14k from the diesel guys last I checked. Still alot but to have D4D in my second gen mini would be sex!!!!!!!!!!!!!!!!!!!!!!!!
  12. Dec 23, 2013 at 4:33 PM
    #472
    Darthyota
    Alberta
    Blown BSP X-Runner
    Last I looked jt was 20000 but I figure 10000 to mod the d4d motor and get some real power out of it
  13. Dec 23, 2013 at 6:00 PM
    #473
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I'll count those as turbo votes. :D
  14. Dec 23, 2013 at 7:22 PM
    #474
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Got the URD Port Fueler and 6 extra 27lb injectors :cool:. Still need to pick up a pump and either FIC 6 or ECU 3. FIC 6 is 1/2 the price so not a hard decision...
  15. Dec 24, 2013 at 9:15 AM
    #475
    hilux30
    hilux30 Well-Known Member
    PEI
    '15 4Dr SB 6MT
    OTT tune 3 degree cam gear OME/Dobinson
    It's funny I was just discussing this with a friend the other day when I was asked what would my next truck be? Since I would have to get a 4dr sooner or later, I was brainstorming/researching a small ball-bearing 'low' pressure (10lbs max) Turbo set-up on a 2.7L manual instead of the current 4.0L Auto... Focus on low end torque, lag is not good when you're using the truck as a 'TRUCK'... cheers
  16. Dec 24, 2013 at 2:53 PM
    #476
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Turbo. It's on the Hilux. :D
  17. Dec 24, 2013 at 4:46 PM
    #477
    subwayaz
    Tucson,Az
    2012 Accesscab; TRD
    Have you checked out the "Unichip" as yet? Might be worth a look.
    http://www.unichip.us
