Turbo vs Supercharger
Discussion in 'Performance and Tuning' started by beastlytaco, Oct 16, 2008.
Which one: turbo or S/C
  1. Turbo
    325 vote(s)
    28.2%
  2. Supercharger
    656 vote(s)
    56.9%
  3. Dont spend the money on either
    171 vote(s)
    14.8%
  1. Dec 9, 2008 at 3:23 PM
    #81
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hey that'd be WILD in a standard cab!!! Less weight! I actually am anticipating hearing your experience when ya do get 1:D
  2. Dec 9, 2008 at 3:41 PM
    #82
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2! I was REALLY happy with my superchaerged Reg. cab 4 popper! :D
  3. Dec 9, 2008 at 3:51 PM
    #83
    beastlytaco
    beastlytaco [OP] Well-Known Member
    Ian
    08 Access Cab SR5
    yeah. if i dont feel comfortable installing one myself, what kind of place normally does that kind of performance work??
  4. Dec 9, 2008 at 4:22 PM
    #84
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It was an easy install. Just give yourself plenty of time. Not sure what kind of shop would install one, though.
  5. Dec 9, 2008 at 4:29 PM
    #85
    beastlytaco
    Ian
    08 Access Cab SR5
    cool. the most work if done is install my catback. so i shouldnt have a problem. i mean it comes with instructions, right? so i should be fine. i just checked their website. alpine developments has a S/C but its only applicable on 1999-2004 tacomas. it is for the 2.7. but would it still fit on my 08??
  6. Dec 17, 2008 at 8:17 PM
    #86
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. the new ones are a little different.
  7. Dec 18, 2008 at 10:43 PM
    #87
    mcollins
    mcollins Member
    Grants Pass, OR
    05 4.0L, TRD, SR5, black
    3" lift, 33" toyo m/t, k&n intake,
    So I suppose that my buddies supercharger for his '02 V6 wont fit on my '05 V6? I don't see why it would, but for the chance to save the cash I gotta ask. And if not, why not? Is there any way to modify it so that it would work?
  8. Dec 18, 2008 at 11:18 PM
    #88
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    01' BSP S/C S-Runner
    S/C, URD fuel Upgrade, 2.2 Pulley, URD crank pulley, Truetrax locker, custom exhaust, plx, scangauge, D/P mod, amsoil drop in, 18x9.5 stern hyperblacks, ACA projectors, Grillcraft blackmesh, Performance Products valance, R/C Tails, B&M Short shifter, QA1 Coilovers all the way around, upgraded strut rod bars with heim joints, poly bushings everywhere lol, 1st model Streetacos bolt on four link!
    no, 3.4 >> 4.0... won't fit.. however for power on the op's 4cyl.. definitely recommend Turbo. You won't get great power gains on a 4 banger with a S/C..
  9. Dec 19, 2008 at 11:17 AM
    #89
    beastlytaco
    Ian
    08 Access Cab SR5
    yeah im not really looking for "racing" power, but more or less power that i can actually use on the hihway. with a turbo i got to reach a certain rpms for that to kick in. s/c its there whenever i need it. i dont have to jump on it to get some HP
  10. Dec 19, 2008 at 3:17 PM
    #90
    VooDooTrip
    VooDooTrip Defector
    Gilbert, AZ
    Low boost turbo is efficient.. say 7-10psi and you only need minimal tuning (little to no lag). The power gains aren't that great for the 4cyl S/C but if you're just looking for a little highway push, then that'll probably be best. I would recommend a piggyback or larger injectors/fuel pump though.
  11. Dec 20, 2008 at 9:59 AM
    #91
    PRE DUKE
    PRE DUKE Member
    sonora CA
    03 prerunner
    I have ran both turbos and super chargers in the past and the super charger is the way to go no lag and your motor will stay cooler, with a turbo you will need alot of air to cool it down.
  12. Dec 22, 2008 at 8:58 AM
    #92
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    It all comes down to where you want your power....
    S/C for low end immediate boost, good for off road grunt..
    Turbo if you want freeway power
    However there are always exceptions to the rule.
    I chose turbo since I am 2wd and dont really need the low end, just more juice on top. 18psi feels really good, especially when that speed racer guy in the Modded mustang wants to "try" and show you whats up..:D
  13. Jan 3, 2009 at 5:40 AM
    #93
    Ridgerunner
    Frank
    Rocklin, Ca.
    Dont let Chris4x4 hear that-he had a pretty nasty SC setup on his 2000 2.7
  14. Jan 3, 2009 at 6:47 AM
    #94
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
  15. Jan 7, 2009 at 12:43 PM
    #95
    j0sh
    j0sh Well-Known Member
    Oklahoma
    '10 TRD Sport 4x4
    AFE Filter, TRD Catback
    here are some pics and a few vids of my supercharged rsx that I parted out and sold before the tacoma
    http://elementdc5.googlepages.com/home
    I would love to get the trd sc for the tacoma now...
  16. Jan 30, 2009 at 7:51 PM
    #96
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    One is exhaust driven one is belt driven, other than that not a whole lot of difference.
  17. Feb 15, 2009 at 10:55 AM
    #97
    Tikibeast
    Tikibeast The Savage
    Victorville, Ca
    2006 Prerunner SR5, Reg Cab totally stock.
    Nada...need some guidance there it's going to see a lot of highway mileage not just trail miles.
    My question is which would be better or more viable for flat open desert running and highway driving?
  18. Feb 15, 2009 at 10:59 AM
    #98
    beastlytaco
    Ian
    08 Access Cab SR5
    well. if your totally flat running, i would go with a turbo set up. but for performance throughout your RPMs, go with a supercharger.
  19. Feb 15, 2009 at 11:32 AM
    #99
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    turboooo vrrrrrrmmmmmmmmmmmm pshhhhhhhh
  20. Feb 17, 2009 at 1:07 PM
    #100
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    Easy question... What do you want your power band to look like (low rpm, med rpm, high rpm)?
    1 - high power, high power, high power
    2 - low power, med-high power, really high power
    *note this is most cases.. not all.
