Turbocharged 2TR-FE
Discussion in '4 Cylinder' started by Boring, Nov 4, 2012.
  1. Nov 4, 2012 at 2:56 PM
    Boring
    Boring [OP] This space intentionally left blank.
    Arizona
    5-lug regular cab
    More than a few.
    Anyone feeling rich?
    http://ozboost.com.au/shop/manifold-and-dump-pipe
    I think this would work on the US spec Tacoma. Maybe they can be fabricated cheaper here? Seems like this and the computer are the main things holding back the 4 cylinders getting turbos. Computers exist, but they'd have to be tuned and programmed for this specific setup right?
    They have a whole kit, but it's for a Hilux with the hood scoop pushing air down through an intercooler on top of the engine. URD's front mounted intercooler looks much better to me.
    If I did it myself, I'd want to lower the compression ratio, so I could keep using "cheap" gas. But, I'm too cheap to do anything like this...
  2. Nov 5, 2012 at 1:48 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Yes, you would have to tune the computer, and more then likely get a little bigger injectors. You can run a little boost on the stock compression ratio. Maybe about 6-7 lbs of boost, and still be able to run 90 octane. Keep it at about a 11.7-13.6 AFR, and everything will be good to go. Why not just custom fab your own down pipe for the turbo?
  3. Nov 5, 2012 at 4:21 PM
    Boring
    Arizona
    5-lug regular cab
    More than a few.
    The downpipe? I was more concerned with the exhaust manifold. Maybe it's common for muffler shops or tuners to build those and I don't know it. That's the first one I've seen for sale anywhere.
  4. Feb 4, 2013 at 2:33 PM
    nik.moretto
    nik.moretto Member
    nathan
    fort mcmurray
    09 taco sr5 2TR
    URD
    this looks interesting...first one ive seen too
    subd
