turbocharging a 4 litre
Discussion in '2nd Gen. Tacomas (2005-2015)' started by commtrd, Jun 19, 2010.
  1. Jun 19, 2010 at 9:45 PM
    commtrd
    commtrd [OP] commtrd
    Corpus Christi TX
    09 Access Cab 4wd V6
    Does any company make a turbocharger setup for the 4 litre V6? Or is the supercharger made by toyota for this engine the preferred way to go to get more from the engine?
  2. Jun 19, 2010 at 9:50 PM
    Rally97Tacoma
    Rally97Tacoma Well-Known Member
    Alan
    Van Nuys
    Trophy 97 Tacoma
    3inch lift in front with rally lights and bumper, as well as lift in the back, upgraded suspension on all fours fiber glass all around, K&N short Ram intake, and little things here and there
    TRD supercharger is around 2g's and it will get a lot out of it
    turbo chargers work with a turbine which generates more air
    to your engine more air to your engine mean there has to be
    more fuel and superchargers work as another belt to your truck
    not just will your engine last long but you wont be forcing it
  3. Jun 19, 2010 at 10:28 PM
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    Sorry if I sound blunt, but you have absolutely no idea what you're talking about do you...
    Superchargers are actually more parasitic to engines than turbos. Both push "more air"...
    :rolleyes:
  4. Jun 19, 2010 at 10:58 PM
    JudeLeBlanc
    JudeLeBlanc Active Member
    Baton Rouge, LA
    06 Single Cab PreRunner SR5
    Weather Techs
    no he doesn't:D
  5. Jun 19, 2010 at 10:59 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    I wonder how much that hurt pulling it from his ass?
  6. Jun 19, 2010 at 11:06 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  7. Jun 19, 2010 at 11:38 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Haha^^^ but on a serious note, Squires turbo systems makes kits that can be made to fit nearly any vehicle... The kit for the 4.0 costs around 5k. Not cheap, but potential for much more power. Only issue I see with the STS is fuel management and delivery. But if you have new injectors, have like the APR X-1, and have that kind of money to throw around it is a great option!
  8. Jun 20, 2010 at 7:30 AM
    commtrd
    Corpus Christi TX
    Good points. I think it boils down to what a person really needs from their truck. I was thinking about a turbocharger setup to get more low-end torque for trailer towing since the 4 litre is underpowered for this truck (IMHO). Others may not agree with that. Then one has to consider the whole truck and remember the weak brakes that should be dealt with if towing at rated capacity. Now if not towing anything or only really light loads, all this would not matter.
    I think I will just leave my truck stock. It is running great the way it is. If I really want to tow heavy I will obviously need to go to a bigger truck with the wheelbase, brakes, and engine power to do that safely. I just don't think the tacoma has the brakes to safely tow at or near the rated 6500 lbs. The taco is good for general running around, general offroad trail use (IFS limitations) and light towing use. Nothing wrong with that, the truck is a light-duty vehicle and as long as that is known up-front all is OK. Probably could be said that if many thousands of dollars need to be spent to structurally change the truck to perform as desired, then you don't have the right truck to start with and the money should be spent to trade for the truck that is actually capable of doing what is needed. This would include solid axle swaps, superchargers, complete brake redo, etc. Reason is that the money spent doing these things will never be recouped on vehicle sale so it just does not make sense.
  9. Jun 20, 2010 at 8:14 AM
    commtrd
    Corpus Christi TX
    Agreed. Words of wisdom there.
  10. Jun 20, 2010 at 8:28 AM
    sbeau1960
    sbeau1960 Well-Known Member
    Scott
    Indianapolis
    09 Tacoma Double Cab TRD Sport Pyrite Mica
    I wouldn't think a turbo would increase low end torque anyway, turbos don't typically produce power down low, they have to wind up and work at higher revs. Of course it depends on turbo size and design but I can't imagine turbocharging would be well suited to the Tacoma unless you're talking a 2wd pure street model.
    commtrd, you make good points about not trying to make the truck something it's not, just fine tune what it is and you'll be happy with it. I enjoy my mods but just went with TRD bolt on stuff (short shift, intake and exhaust) and basic suspension upgrades. I tow a 6x10 enclosed motorcycle trailer easily, could certainly pull a boat or larger trailer. I offroad mine occasionally, very competent through muddy roads and fields. It's a great all around truck other than less than stellar fuel economy, but that's no different than any other 4x4 out there.
  11. Jun 20, 2010 at 8:42 AM
    commtrd
    Corpus Christi TX
    My truck is really a nice truck and works great for what I am using it for. I may need to tow a larger travel trailer (would like a 25' fifth wheel) and this access cab truck clearly will not do that. I would like to keep this truck AND get a 3/4 or 1 ton diesel to tow with...not sure the boss [wife] is going to be OK with that though. My taco does tow my 19' flats fishing boat OK it's not a ball of fire but it does it. The brakes suck I really wish I could do something about that. The truck goes through deep sand like nobody's business so great for going to the beach. I love this truck it just has some fundamental issues that should have been done right from the factory especially for what the truck cost. For general use it is just fine...when starting to push it the truck starts to show its limitations.
  12. Jun 20, 2010 at 10:50 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    Depends on the size of the turbo, fueling and engine load. Beign a diesel guy I prefer turbo's:D
  13. Jun 20, 2010 at 12:14 PM
    cummins6speed
    Actually the more fuel you add to a diesel the hotter it gets, whereas it is the opposite with a gas application. This is why you can slap a big turbo on a diesel that flows a lot without necessarily needing fuel upgrades. On a gas engine the more air you have the hotter it runs and this is why you need those fuel upgrades with adding a turbo or S/C
  14. Jun 20, 2010 at 12:51 PM
    Trapper6speed
    Trapper6speed Hacksaw engineer
    Stock
    I think some one on here has a turbo kit forsale on craigs in FortWorth. I think it's everything except the injectors and programming.
  15. Jun 20, 2010 at 1:00 PM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    i wish!!!!!!!!!!!!
  16. Jun 20, 2010 at 1:02 PM
    misterquad
    misterquad Well-Known Member
    Skip the turbo and S/C and just trade it for a Tundra or a vehicle with the power you need. IMHO I think both they hurt your resale and you waste your money. I would never buy a vehicle that has aftermarket engine modifications. I am just saying.
  17. Jun 20, 2010 at 1:30 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you need more low end torque you'd need a supercharger, not a turbo. Turbo's turbines are powered by exhaust, which only start spooling enough to boost after you get into the higher RPM band (especially a single larger turbo, smaller twins can spool faster). However for towing on a petrol engine... a supercharger is really the only solution I'd recommend. It will run cooler and be more robust, you can shut it off like normal instead of waiting for a turbo cool down time (remember turbo's get up to around 14,000F).
    Also, if the TRD supercharger isn't your cup of tea, URD offers a great package in Mark I, II, and III packages. Mark III with supporting mods (including a valve body upgrade for the auto transmissions) will throw down 400hp+.... Gadget's X was running about 420 with it last I checked.
    Also note, personally down the line I intend to supercharge mine. (that will be awhile though, $ is a bit tight haha). I couldn't really see running turbo's on here... doesnt' really fit a 4x4 truck's nature imo. It really should have more immediate power on demand instead of waiting for spool, especially in off road or towing situations.
    Something else to consider, if you get the TRD Supercharger with stock stuff and let the dealer do the install... your full warranty on the truck is still in effect. Seriously you can't ask for more on that front. the 2009-2010 TRD Supercharger fit kit was just recently released too. Check out trdparts4u.com
  18. Jun 20, 2010 at 2:57 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Upgrade the pads, get stainless brake lines and possibly change the tires. These are a few things I could think of to improve braking performance. Your system may need a flush as well.
  19. Jun 20, 2010 at 3:09 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    Yeah if it was 2k i would have one along with everyone else on here.
    That STS turbo kit looks like a china made pile of shit.
  20. Jun 20, 2010 at 3:16 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Custom made rear mount.. not the STS. Would be plenty of fun
