Turd gen unable to start until physical shock is given
Discussion in '3rd Gen. Tacomas (2016-2023)' started by krzysnwbrdr, Jan 29, 2019.
  1. Jan 29, 2019 at 3:15 AM
    krzysnwbrdr
    krzysnwbrdr [OP] Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    So my taco is in Japan, so pretty much no way for me to have dealer looked at it.(Japanese Toyota refuses to do ANYTHING with it)
    So I can only ask your opinions and experience and solve problems myself.
    Today, I experienced the vehicle unable to start up nor detect the key.
    I stopped at a gas station to refuel, the “Trip Reset” happened. I was like okay again. No biggie.
    Then I stopped at a drug store.
    When I walked away from the car, I couldn’t lock the car even though I tapped on “Lock” on the remote several times.
    No response. I thought it’s only going to be a few minutes stop so it’s not a big deal, and I left it unlocked.
    After shopping for 5min, I get on the car and tried to start it up. No response at all. No acc lights or error came on the dash. I realized fuel gauge and tachometer needle was not resting at “zero position”. They were just sitting in the middle of gauge.
    No response whether how many times I push start, lock, unlock or anything.
    I opened and shut the door with decent force to give some shock, then all gauge went to “zero position”.
    When I got home, it happened again. Same solution applied. Problem solved.
    How many people have experienced this? Do you know the reason why?
  2. Jan 29, 2019 at 3:29 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Loose battery cable
  3. Jan 29, 2019 at 3:48 AM
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    Yeah check your connections at the battery or could be a dead key fob battery.
    When I bought my truck the salesman told me that if my fob battery ever died and i needed to turn the truck on, hold the key fob in front of the start button, press the button and the truck should detect it and start.
    Haven't tried it myself but worth a shot.
    SR-71A, Gunshot-6A and boynoyce like this.
  4. Jan 29, 2019 at 5:09 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    As stated, sounds like a bad battery or loose connection. Keep us posted and good luck.
    boynoyce likes this.
  5. Jan 29, 2019 at 8:01 AM
    krzysnwbrdr
    Masaki
    I get it if it was after working on battery or touching. But what I don’t get is this happened all the sudden and I haven’t touched battery for nearly a year.
    But I’ll double check...
  6. Jan 29, 2019 at 8:03 AM
    krzysnwbrdr
    Masaki
    No the fob battery was replaced a few month ago. And when it died on me, the trick didn’t work for me. I had to run into a Honda dealer and beg them to replace the battery.lol
    And fob light did cane on when I pressed the button.
    The needle stuck in the middle of gauge is what’s throwing me off and making me worry....
  7. Jan 29, 2019 at 8:06 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    OP calls his truck a turd because it doesn't start. All he had to do was check the battery connection... :rofl:
    JCOOR likes this.
  8. Jan 29, 2019 at 8:11 AM
    Whitetail Assassin
    Whitetail Assassin Well-Known Member
    Tedric
    West Virginia
    2024 Underground TRD Off-Road 6 Speed MT
    If that “Turd gen” was a manual you could at least take the key fob detection out of the equation. Lol! Best of luck OP. Let us know how you get it resolved. Hopefully the battery solves it.
    Spare Parts and shakerhood like this.
  9. Jan 29, 2019 at 8:17 AM
    diabetiktaco
    Eric
    New Jersey
    2022 GX460
    Stuff shakes loose over time. Not the definite cause but given how simple it is to check I'd start there.
  10. Jan 29, 2019 at 8:27 AM
    shane100700
    shane100700 Bed, Bath & Beyond Crawler
    Montana
    2019 DCSB, OR
    Rocket Boosters
    We don’t know that because OP hasn’t trouble shot anything. Just got upset about it.
    OP- if you are in Japan (Navy, Marines?) your truck was probably on a boat at one point? Took mine almost a month to get from NJ to HI. That’s a long time to sit or barely be run.
    Check battery connections, make sure they are tight. Most batteries now have a light, see if it’s green, if it’s green or not, still use a voltmeter on it. Make sure the alternator connections are good. Replace the fob battery- it’s like $3, why are you begging Honda to do it?! If you are on a military post, they probably have a Firestone, most do but not sure about overseas as out of the country. Willing to bet there is a shop there though. If you are military and no shop, there is probably a mechanical hobby shop on post, go there. Any of this should get you started.
  11. Jan 29, 2019 at 8:32 AM
    LivinOnEdge
    Land of The Lost
    Not any better, shaming your truck on the internet because you don't know the root cause. :goingcrazy:
    Could be a big deal, or it could not be. We don't know, neither does he.
    Whitetail Assassin likes this.
  12. Jan 29, 2019 at 8:34 AM
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    That’s odd. Without a wire diagram it’s going to be tough to know what to look for. Something easy I’d try is leave the battery completely disconnected for a while and see if it resets.
    Are the gauges stuck in the middle even with the truck off?
    Any work/ mods done to it recently?
    Gunshot-6A likes this.
  13. Jan 29, 2019 at 8:37 AM
    shane100700
    Montana
    2019 DCSB, OR
    Rocket Boosters
    Agreed. Wasn’t a knock on you, was more of a knock on absolutely zero trouble shooting.
    LivinOnEdge[QUOTED] likes this.
  14. Jan 29, 2019 at 8:38 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Looks like you got some good serious answers to your dilemma.
    Im curious as to what the Japanese public thinks of the Tacoma.
    I have seen some IG accounts, and TW accounts that look to be from Japan. MasaCollector comes to mind.
  15. Jan 29, 2019 at 8:39 AM
    LivinOnEdge
    Land of The Lost
    :fistbump:
  16. Jan 29, 2019 at 8:43 AM
    Whitetail Assassin
    Tedric
    West Virginia
    I would look for chewing from Japanese rats on your wiring. Lol!
  17. Jan 29, 2019 at 11:33 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    I bet it's the FOB battery.
    If not, then it may be associated with the gauge cluster resetting issue...… That'll be a PITA for you.
    Good luck.... :thumbsup::thumbsup::canada:
  18. Jan 29, 2019 at 5:22 PM
    krzysnwbrdr
    Masaki
    Umm yeah if that was the cause.
    I did check it just now. Tight in place
  19. Jan 29, 2019 at 5:23 PM
    krzysnwbrdr
    Masaki
    Yup the needle was stuck when it was shut off. I only realized it when I tried to restart it and there was no response.
  20. Jan 29, 2019 at 5:26 PM
    krzysnwbrdr
    Masaki
    People think I’m crazy driving DCLB in Japan. But it’s the same size as Tundras.
    I just need to be careful which roads to take and not always follow my Navi as sometimes guides me to narrow back roads where I can’t drive by.
