Turd gen unable to start until physical shock is given
Discussion in '3rd Gen. Tacomas (2016-2023)' started by krzysnwbrdr, Jan 29, 2019.
  1. Jan 29, 2019 at 5:27 PM
    krzysnwbrdr
    krzysnwbrdr [OP] Well-Known Member
    Masaki
    2016 Black Tacoma TRD Sports DCLB
    Nah I thoroughly checked wires as well when I checked the battery connection. :(
  2. Jan 29, 2019 at 5:29 PM
    krzysnwbrdr
    Masaki
    Ty.
    I thought of the same in the first place, The thing is the fob battery was replaced less than 6mo ago, the remote lit red light when I pressed the button.
    Plus the gauge needle which tells me something else might be causing this as when it gets reset, it detects the key.
  3. Jan 29, 2019 at 5:34 PM
    Jes
    Jes Well-Known Member
    Knoxville
    2017 Taco TRD Pro Cement
    Check you battery voltage...
  4. Jan 30, 2019 at 1:23 PM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    What is this "gauge needle"..? Never heard of anything like that. :confused::confused:
  5. Jan 30, 2019 at 4:49 PM
    krzysnwbrdr
    Masaki
    Im talking about the needle showing which RPM your running @ on tach, the needle showing how much fuel you got in your tank on your dash.
    Cant think of other words atm...
    over60[QUOTED] likes this.
  6. Jan 30, 2019 at 4:50 PM
    krzysnwbrdr
    Masaki
    Ill check its static voltage and also at idle when i get a chance. Just to make sure...
  7. Jan 30, 2019 at 4:51 PM
    krzysnwbrdr
    Masaki
    I havent changed battery since i bought the truck new, so its actually not a bad time to replace...
  8. Jan 30, 2019 at 5:23 PM
    over60
    Muskoka, Ontario
    Sorry for the misunderstanding. It went over my head, I guess.
    So if your gauges are acting like you are in Roswell, NM,..... I think battery should be doing it.!:thumbsup::thumbsup:
  9. Jan 30, 2019 at 5:34 PM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Hopefully you can get your issue resolved over there.
    Although this should answer anyone's questions regarding taking a 3rd gen overseas. Toyota of Japan won't work on the North American Tacoma because they are not familiar with it.
  10. Jan 30, 2019 at 5:40 PM
    Arailt
    Arailt Well-Known Member
    Dallas, TX
    2019 GX460
    You should send the Taco home, buy a manual diesel 80 Series, and then bring it back home with you to the States.
    krzysnwbrdr[OP] likes this.
  11. Jan 30, 2019 at 6:16 PM
    krzysnwbrdr
    Masaki
    Ty. Yes, my understanding is as soon as the vehicle leave NA, it voids its warranty which is a bummer. :(
  12. Jan 30, 2019 at 6:21 PM
    BlueFalconActual
    BlueFalconActual Some dude
    2017 DCSB TRD OR 4x4 MT
    Now I’m craving some gas station food from Lawson or Family Mart.
    krzysnwbrdr[OP] and trackdaybro like this.
  13. Jan 30, 2019 at 6:49 PM
    trackdaybro
    trackdaybro Well-Known Member
    The clear umbrella I bought from 7-eleven in Tokyo was the best one I’ve ever had. Brought that back to the states with me.
  14. Feb 3, 2019 at 8:30 PM
    krzysnwbrdr
    Masaki
    Just an update. I didnt have chance to check on static/charging voltage yet, but this incident most likely caused the vehicle to isolate power from battery. I tried opening window and auto open/close, nor passenger window did not work which tells me the window position memory was reset when this happened. I now cannot duplicate this "stall", so i cant narrow down the actual cause...
    Ill post voltages when im done checking.
  15. Feb 3, 2019 at 9:45 PM
    #35
    krzysnwbrdr
    Masaki
    Just a note, that yesterday in Tokyo highway, for the first time i saw 3rd gen driven.
    We gave thumbs up and chuckled. ;)
    Mattimus85, Arailt and shakerhood like this.
  16. Feb 4, 2019 at 7:17 PM
    #36
    krzysnwbrdr
    Masaki
    So I did check the voltage and there is no problems. Ill have shop perform a load test this week.
    Static: 12.8VDC
    Engine On/ HL off: 13.9VDC
    Engine On/HL on: 13.8VDC
    Charging system in tact, the battery seem to be okay as well.
  17. Feb 4, 2019 at 7:18 PM
    #37
    krzysnwbrdr
    Masaki
    Do you really not see those umbrellas in the states?
    I might have to sell it on ebay.lmao
    #37
