TurdGen... 3rd Gen Tacoma off to lemon law
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DoveGabanna, Mar 6, 2017.
Thread Status:
Not open for further replies.
  1. Mar 6, 2017 at 10:59 AM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    So then is there a way to source 2nd gen fluid to put in a 3rd gen? See if it makes a difference?
    As an aside I think this really really needs posting in the dedicated diff whine thread because it might have some weight behind it. Playing around with fluids is cheap & easy, relatively speaking. If we can find that it's just a friction modifier (or lack thereof) in the diff oil we can put the howl issue to bed. If it's not, no harm done and everyone is only collectively out a few quarts of gear oil.
    It wouldn't explain some of the random failures but it's a start, as my only other guess would be a pinion issue- I've noted that it seems like 4.3 geared folks have no whine, while 3.9's do- ring gear is the same, pinion is different.
  2. Mar 6, 2017 at 11:01 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The late 2nd Gen uses the same gear oil as 3rd Gen
    Storman and Patrick1046 like this.
  3. Mar 6, 2017 at 12:32 PM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    In Alabama maybe
  4. Mar 6, 2017 at 4:13 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    I have a 4.3 and definitely have the whine (currently at 10k miles but it started at like 2000 miles); I think a lot less folks have manuals in general so there are less data points to pull. I'm changing the diff fluid in a few weekends (Amsoil severe gear 75-90). I'm hoping that helps somewhat. Though Toyota's brochures are unclear, I'm relatively certain I don't have a true limited slip so I won't be adding the additive for it.
    OA
    shakerhood likes this.
  5. Mar 6, 2017 at 6:59 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    Additive is only required if your limited slip diff has clutches like positrac etc. Basically a spring keeps pressure on the clutch disks and the additive is there to allow smooth slipping and not lurching and grabbing hard resulting in chatter when turning.
  6. Mar 6, 2017 at 7:08 PM
    MechE
    MechE Member
    Sam
    Flagstaff, AZ
    2017 Black Tacoma TRD OR 4x4
    I have a 2017 TD OR, considering getting the TSB but I'm not sure I really need to. Did you trade in your 2016 for a 2017? And you didn't need to do anything for the 2017?
  7. Mar 6, 2017 at 11:06 PM
    TacomaGinger
    TacomaGinger Well-Known Member
    San Diego, CA...for now
    2017 TRD Off-Road
    Snugtop Rebel, Bedrug, Grillcraft
    Same here. When is the TSB due? I'm at 1100 miles on my 2017 TRD OR.
Thread Status:
