Turkey Fryer - Timer by-pass and/or hose replacement options.
Discussion in 'Food Talk' started by Sprocket, Sep 30, 2018.
  1. Sep 30, 2018 at 6:12 PM
    Sprocket
    Sprocket [OP] Well-Known Member
    Hi All,
    Got a new fangled turkey fryer with the swell timer thing that has stopped working - at the worst possible moment...
    Has anyone just swapped out the hose assembly and/or used an adapter to make the original hose fit?
    I've read up on the various by-passes - timer wiring and thermo couple delete, etc.
    I'm just wondering f I can buy a replacement hose - possibly from an older unit (no jokes please) and use it instead. Cleaner install and all that...
    Thanks,
    Sprocket
  2. Sep 30, 2018 at 9:03 PM
    bvbull200
    bvbull200 Well-Known Member
    Bryan
    DFW, Texas
    2013 DCSB SR5 Prerunner Texas Edition
    Fresh wiper fluid
    I have an older one with no timer and a newer one that only lets you go for 15 minutes at a time without turning the little timer knob. I can swap mechanisms with one another, if I wanted to. Haven't seen a need, but I could.
    Not sure if that's what you're looking for.
    You should be able to buy a used hose with the appropriate fitting, then just connect it to your burner. Pretty standardized thread size, I believe.
  3. Oct 1, 2018 at 6:14 AM
    Sprocket
    Thanks - it's the thread size that would be the key - Local shops don't carry the replacement hose so I'd like to only order it once and void the return games.
    Thanks
  4. Dec 1, 2018 at 10:11 AM
    Sprocket
    Update: After checking out some of the vids I went with a 5/16" Flare Cap for $4 at the local HD store.
    Adapting a 1/4" hose to a 3/8" inlet wasn't possible
    The only thing that concerns me is the push button on the valve body - I'll check it all for leaks with soapy water before I run it
    bvbull200 likes this.
