Turn a 4x2 into a 4x4.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jrad3110, Dec 4, 2018.
  1. Dec 4, 2018 at 8:24 PM
    #41
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    I reckon a mall parking lot would be kinda off road, or for the hard core a dirt or gravel driveway.
    Avail211[QUOTED] likes this.
  2. Dec 4, 2018 at 8:39 PM
    #42
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Needed for VSC unless they don't want full functionality.
  3. Dec 4, 2018 at 8:41 PM
    #43
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    VSC has its own computer though?
    If so all you have to do is connect the vsc wire from the 4wd computer to the vsc computer. Or why even connect it? Vsc dosent need to know 4wd exists
  4. Dec 4, 2018 at 8:43 PM
    #44
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    I didn't think it was April 1st yet.........
  5. Dec 4, 2018 at 8:45 PM
    #45
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Just slap on some TRD Offroad 4x4 stickers? And many won’t even know the difference since they look OEM.
  6. Dec 4, 2018 at 8:51 PM
    #46
    OnHartung'sRoad
    You know who is back...
  7. Dec 4, 2018 at 8:54 PM
    #47
    OnHartung'sRoad
    But no crawl control?! :eek:
  8. Dec 4, 2018 at 9:04 PM
    #48
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Absolutely it does. Wheel rotation comparison. Wheel sensors feed through ECU because of throttle control.
    Look, the cheap easy way is to trade. Expensive and hard way is to convert. Two ways to do it hard... simple or complicated. I think there are shops out there that are good enough to replicate all current functions but to exactly copy Toyotas way would be a long $$$$$$$ project.
  9. Dec 4, 2018 at 9:08 PM
    #49
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    I was looking in to this a long while back when I had a 2WD, and like it was said on here, unless you're mechanically inclined, the labor is gonna kill you, plus pretty much completely screw any warranty you might have as they can outright state that anything that happens to your truck is due to 4WD aftermarket conversion.
    That being said, off the top of my head here's what you'll need-
    New 4x4 Transmission (2WD transmissions are longer to accommodate for no transfer case)
    Transfer Case
    New Driveshafts front and back
    Front axles
    Front Diff
    Mounts for diff
    Spindles *should* be fine as 2WD spindles just have a dust cap inside that can be popped out and 4WD hub connected
    4WD hubs
    Either go with a full conversion to make it as close to stock as possible and get a 4WD ECU/4WD switch in your dash and all that, OR I think Rock Solid Toys makes a harness to have a switch on your dash to activate your front diff. 4WD trucks have stuff built in that when you switch to 4WD it activates the Transfer case as well as a 4WD module on your front diff that engages both axles. Without that front module I think you're technically in 3WD lol. You might be able to work it out to have multiple switches to just engage the transfer case and all that, or go mechanical engagement from RST (FJ Trasnfer case conversion)and not have to bother with ECU and 4WD button, but thats a whole nother ballgame.
    Again, unless you're doing it yourself, the conversion labor plus parts cost far outweighs any loss you might take on a trade in for a 4x4.
    hiPSI and CaptainBart45 like this.
  10. Dec 4, 2018 at 9:09 PM
    #50
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    I don’t remember where but I heard of someone doing it in a 17 and from what I remember it ended up costing like $18,000 using all OEM parts
  11. Dec 4, 2018 at 9:22 PM
    #51
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Mine came with 4X4 and never used it in almost 2 years. HAVE to remember to put it in 4X4 from time to time to move the gears.
    hiPSI likes this.
  12. Dec 4, 2018 at 9:48 PM
    #52
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I've had to use 4WD a dozen times today! Slick and snowy and I was at a job site off road this morning. I hate mud. Snowy mud.
    tonered and Nunya Bizness like this.
  13. Dec 4, 2018 at 10:06 PM
    #53
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    Just trade it in. If you can afford it.
    Nunya Bizness likes this.
  14. Dec 4, 2018 at 11:26 PM
    #54
    Nunya Bizness
    Listen to this guy... he is wise beyond his yrs
    tonered and rblalliance like this.
  15. Dec 5, 2018 at 1:27 AM
    #55
    eon_blue
    Azusa, CA
    I've seen a few SAS'ed 3rd gens...not sure if they started out as stock 4x4s but an SAS conversion might as well begin with a 4x2 as everything in the front drivetrain gets re-done basically.
    Best first post ever
  16. Dec 5, 2018 at 1:30 AM
    #56
    eon_blue
    Azusa, CA
    I don't think I've ever seen a case where someone wanted to get rid of their 4x4 for a 2wd version of the same vehicle...not saying it hasn't happened, I'm sure it has..but definitely not common.
    Though I know of one member on here that ditched his 4wd components to make it a 2wd for the sake of race truck, which is about the only valid excuse to do such a thing lol.
  17. Dec 5, 2018 at 3:14 AM
    #57
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    Why does it need to know you are in 4wd if it’s just sensing wheel speed? The hubs are the same except for the splined internals on the 4wd. I think you are over thinking this.
  18. Dec 5, 2018 at 5:06 AM
    #58
    TailHook
    TailHook Oh, what shall we do with a drunken sailor?
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    This post reminds me of a story...
  19. Dec 5, 2018 at 7:27 AM
    #59
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    You are turning the front wheels into driven wheels. They can now spin (think snow)
  20. Dec 5, 2018 at 7:28 AM
    #60
    DeltaBravo
    DeltaBravo Do you know what nemesis means?
    Waste Management's residential dumpster rental allows you to quickly find the right size dumpster for your project, schedule delivery and pay, all in just a few steps.
    The vehicle commonly referred to as "The War Rig" is a 78 foot 18 wheeler based on a Tatra T815
    Goats and a goblin?
