Turn dial next to rr diff lock
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotasTacos, Oct 6, 2021.
  1. Oct 6, 2021 at 2:51 PM
    YotasTacos
    YotasTacos [OP] New Member
    03 Tacoma Pre
    I have a little turn dial next to the button for my rear differential lock in my 03 prerunner 2wd. The dial shows what appears to be something similar to my speedometer dial with 5 little white dashes underneath. Only owners manual I have came from the dealership (shows basic info on taco,, tundra, and T100) and I can't find answers on google. Anybody know the use of this?
    Digiratus and 1997tacomav6 like this.
  2. Oct 6, 2021 at 2:52 PM
    1997tacomav6
    Denver
    It’s adjusts the dash light, speedo light
    Rachelsdaddy and Taco critter like this.
  3. Oct 6, 2021 at 2:55 PM
    nictarine
    nictarine Well-Known Member
    Nick
    Turbo knob or it adjusts the dash lights when the lights are on
    Bivouac likes this.
  4. Oct 6, 2021 at 4:54 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    It is a rheostat to dim the dash lights, radio and Hvac panel it does not effect the warning lights
  5. Oct 7, 2021 at 3:56 PM
    Billison_
    Billison_ Why does beer pair so well with wheeling?
    Billy
    ‘01 Ext Cab With Spension
    I changed the air freshener to a new one, one time.
    Makes your truck faster
    Mr. Arizona likes this.
  6. Oct 7, 2021 at 4:05 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    That lowers the spare tire…
  7. Oct 8, 2021 at 12:23 AM
    Diemaster
    Diemaster Active Member
    Josh
    San Bernardino
    2004 SR5 Tacoma 4x4 V6 Double Cab
  8. Oct 8, 2021 at 12:27 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Hahahahaha Friday post? Dimmer for the dash lights
  9. Oct 8, 2021 at 6:10 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW. :cookiemonster:
  10. Oct 15, 2021 at 9:53 PM
    Taquito21
    Taquito21 Member
    Nathan
    2003 Tacoma TRD Off Road
    Panel dim switch. It brightens or dims the dash lights. Welcome aboard!
  11. Oct 15, 2021 at 9:58 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Apexi VTEC controller
