turn on sink water, smells like rotten eggs
Discussion in 'Off-Topic Discussion' started by denali climber, May 11, 2013.
Thread Status:
Not open for further replies.
  1. May 11, 2013 at 12:06 PM
    denali climber
    denali climber [OP] Well-Known Member
    I moved into a new apartment and when I turn on the water in my bathroom sink, it smells like rotten eggs for a few seconds.
    What the heck ?
  2. May 11, 2013 at 12:09 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Probably shit in the pipes or water heater. You could ask maintenance but I doubt they will do anything. My water smells weird but tastes delicious.
  3. May 11, 2013 at 12:09 PM
    XIGUNHAWKIX
    XIGUNHAWKIX Just a desert dude.
    Luke
    Taos, NM
    SR5 4WD Base Project Truck
    Entune touchscreen display, JBL system, blacked out, Icon 2.5 Remote Resis, TC UCA's, 50" LED LightBar. Pelfreybilt bumper.
    The water may have a high sulfur content, our ranch in central texas has the same issue when the water is turned on.
  4. May 11, 2013 at 12:12 PM
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    That's how the water is at my place. The smell goes away fairly quick though.
  5. May 11, 2013 at 12:14 PM
    CrazyCooter
    CrazyCooter Hold My Beer!
    Johnathan
    Virginia
    is it well water? If so well water has a high sulfur content and it usually means the filter on the well pump needs replacing.
  6. May 11, 2013 at 12:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Not that it will make any difference but I'd open all the taps and let it run for several hours. [​IMG]
  7. May 11, 2013 at 12:20 PM
    TOY4JMEBOOZE
    TOY4JMEBOOZE Well-Known Member
    Winchester, CA
    2018 Chevy Tahoe
    Is it the water itself or the drain? We had that issue where the hand sink smelled when the water drained. Turned out to be a broken pipe and the water was draining into dirt underground
  8. May 11, 2013 at 12:23 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    now you can fart in the shower and get away with it.
  9. May 11, 2013 at 12:24 PM
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    from google.
    Hydrogen sulfide gas (H2S) can occur in wells anywhere in Minnesota, and gives the water a characteristic "rotten egg" taste or odor. This brochure provides basic information about hydrogen sulfide gas and sulfur bacteria and discusses actions that you can take to minimize their effects.
    What are the sources of hydrogen sulfide in well water and the water distribution system?
    Hydrogen sulfide gas can result from a number of different sources. It can occur naturally in groundwater. It can be produced by certain "sulfur bacteria" in the groundwater, in the well, or in the water distribution system. It can be produced also by sulfur bacteria or chemical reactions inside water heaters. In rare instances, it can result from pollution. The source of the gas is important when considering treatment options.
    Are sulfur bacteria or hydrogen sulfide harmful?
    In most cases, the rotten egg smell does not relate to the sanitary quality of the water. However, in rare instances the gas may result from sewage or other pollution. It is a good idea to have the well tested for the standard sanitary tests of coliform bacteria and nitrate. Sulfur bacteria are not harmful, but hydrogen sulfide gas in the air can be hazardous at high levels. It is important to take steps to remove the gas from the water, or vent the gas to the atmosphere so that it will not collect in low-lying spaces, such as well pits, basements, or enclosed spaces, such as well houses. Only qualified people who have received special training and use proper safety procedures should enter a well pit or other enclosed space where hydrogen sulfide gas may be present.
  10. May 11, 2013 at 12:27 PM
    anotherreject
    anotherreject Well-Known Member
    Mine did that when i first moved. I let all the faucets in the house run for a few minutes and it went away
  11. May 11, 2013 at 8:32 PM
    El Chip
    El Chip Well-Known Member
    We get "rotten egg" sulphur water once a year. We are on well and septic. In our case it is bacterial. It is not dangerous to drink, it just smells terrible. There are other causes for this smell, so you have to determine the cause before a fix can be had. In our case, we do the following:
    Bypass softener if you have one.
    A bottle of bleach poured down the well.
    Recirculated via a garden hose for 15 minutes (put garden hose down well and run for 15 minutes)
    Then run every faucet until you can smell the bleach and shut off. Run the hot water out of the bathtub to get it some of the bleach into the hot water tank, especially if bacteria related.
    Leave for 2-24 hours, don't use the water. 4-6 hours works well for me.
    Attach garden hose outside to nearest drain, forest, whatever away from the house, and run the water until the bleach smell subsides. Run your taps a bit and flush your toilets and you are good to go.
    Skip the last step if you don't have a septic tank.
  12. May 11, 2013 at 8:42 PM
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    Shocking (bleach treatment) won't help long term if you have Hydrogen Sulfide gas in well water.
    It can help to install a "contact tank" where the well water enters the building. It gives the water the opportunity to gas off before it is delivered to the tap. Talk to a local plumber or water treatment specialist (I recommend the plumber. water treatment guys like to sell equipment).
  13. May 11, 2013 at 9:57 PM
    denali climber
    I'm not on a well so it leads me to believe there could be bacteria or something in the water.
  14. May 13, 2013 at 3:24 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Probably all the shitty napkins your flushing :rolleyes:
  15. May 13, 2013 at 3:31 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you're not on a well, it might be worth having the water tested. I grew up in a house that had sulfur water (it was on a well), never heard of public water having sulfur.
  16. May 13, 2013 at 3:33 PM
    Manwithoutaplan
    ID
    :rimshot:
  17. May 13, 2013 at 3:40 PM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    mine was the same way the first two weeks i moved in, now it's normal smelling water.
  18. May 13, 2013 at 3:44 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    Dude this is Dante's Peak 2.0!!! A volcano is about to erupt in your little town and if you don't trust the hunky Pierce Brosnan because he took a cup of water that smelled like rotten eggs and proved that it means a volcano is about to blow! Hop in an armored up Suburban and drive it straight into the nearest mine shaft right meow!!!This water smells fishhay fishhaaayyyyy[​IMG]
  19. May 13, 2013 at 3:47 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    perhaps it's just an after effect, of cleaning your faucets with shit stained napkins?:eek:
  20. May 14, 2013 at 5:13 AM
    guitarjamman
    guitarjamman Well-Known Member
    Zach
    Northeast
    2019 Ram 2500
    Does the cold water have a shitty smell or is it just the hot water?
    Seeing as you are on town water (not a private well), I am almost 100% positive it is the hot water heater. Bacteria in the water reacts with the magnesium and aluminum anode rod in the tank which release hydrogen sulfide gases.
    Put a cup under the faucet and turn on the cold water - smell the water and report any staaank. Go to a different faucet and do the same thing with the hot water. Best way to eliminate the smell would be to replace the anode rod in the hot water heater with a Zinc/Aluminum one.
Thread Status:
