turn on sink water, smells like rotten eggs
Discussion in 'Off-Topic Discussion' started by denali climber, May 11, 2013.
Thread Status:
Not open for further replies.
  1. May 14, 2013 at 7:01 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    sounds like any hotel in Florida,
    orlando specifically. town water is shite
  2. May 14, 2013 at 11:11 AM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
    Well, if it's not well water... check your plumbing for leaks. If a pipe is broken, that might have something to do with it.
  3. May 15, 2013 at 1:23 PM
    oldstick
    oldstick Medicare Member
    GA
    Put it in jugs and advertise it on ebay. There is a state park here in ga with a natural spring coming out of the rocks that constantly runs with sulpher water. It was a sacred medicinal spot for Native Americans back then.
    Nowadays people come from all over the state standing in line with dozens of jugs to fill. Several told me it sells pretty fast around Atlanta to the "old remedy" believers.
  4. May 15, 2013 at 1:24 PM
    oldstick
    GA
    Make that any tap water in FL (or extreme southern GA)
  5. May 15, 2013 at 1:30 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    Like i said, Tell me how expensive those rolls of TP sound when your whole water system goes to shit :rimshot:
  6. May 15, 2013 at 1:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    wut
  7. May 15, 2013 at 8:19 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    Its probably your drain. I have the same problem every once and a while in my bathroom sink. Had my water checked by the water department & the guy told me the water is fine but it's my drain thats causing the smell. I confirmed this by running the water for a minute with the drain stopper closed. Sure enough, no smell. As the water goes down the drain, air comes up & you get that smell of rotten eggs from deep down in the drain. You might want to get your drains cleaned out. It might help. Sometimes they will clean them out from the roof where the vents are for the drains. Hope this helps. Good luck!:D
  8. May 15, 2013 at 8:22 PM
    OZ-T
    Peter North
    British Columbia
    If you have a trap on your drain , no gasses should be able to escape
  9. May 15, 2013 at 8:32 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Inside of hot water tanks is something called an anode rode. They are meant to help prevent the corrosive nature of elements in the water by attracting the elements to the rod. Eventually the rod becomes completely corroded. After this happens the water will smell like sulfur.
    If this is the case for you, then the rod needs replaced or a new water heater.
Thread Status:
