Turn or Replace rotors?
Discussion in 'Technical Chat' started by JJ04TACO, Feb 10, 2018.
  1. Feb 10, 2018 at 10:54 AM
    JJ04TACO
    JJ04TACO [OP] Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    So after 190k miles I thought for sure I'd need to replace the rotors. Turns out they measured 21.9mm and 22.0 respectively with a min thickness of 20mm.
    New rotors at $70 ea, measured 22.0. I was stunned honestly.
    So after 14 years of duty, my gut says to still replace. I have a place resurfacing the old ones now. I'll see how much they took off but, stopping being of huge importance and all...
    What are your thoughts of using a 14 year old, rode hard rotor?
  2. Feb 10, 2018 at 7:25 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    At those miles, I'd replace.
    Check am-autoparts I got rotors and oe style ceramic pads for $85 delivered.
  3. Feb 10, 2018 at 7:31 PM
    tcjacado
    tcjacado Well-Known Member
    If they aren't giving you a vibration or braking issues I would say just replace the pads and be on your way.
    On my 2nd gen
    I bought from auto zone out here on the west coast and would buy the lifetime ceramic pads. When they get low, go buy a new set and install them. Then return the others for your money back on them because they are lifetime.
    SandyTaco4x4 likes this.
  4. Feb 10, 2018 at 7:47 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I'm at 187,000 on my Tacoma. Rotors have been turned twice. They will need to be replaced next time, but that should get me well over 200,000 miles. If it ain't broke don't fix it. Apparently it must cost a lot more to get them turned in some places, but around here I can have them taken off, turned and put back on for less than just buying 1 rotor. Not including labor, shipping or taxes.
  5. Feb 10, 2018 at 9:38 PM
    Chroad
    Chroad Well-Known Member
    Birmingham, AL
    2003 Tacoma 2.7L Double Cab
    Still stock...
    I never turn rotors on any of my vehicles any longer. Turning isn’t inexpensive in my area, so getting new ones is only marginally more expensive. When I did turn them, I always felt like they warped within about 10k miles and I needed to replace them then.
    sparkystaco likes this.
  6. Feb 10, 2018 at 9:53 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    $20 per rotor here for turning. Not bad but rotors are cheap, even OEM.
    After some thought, I went new. Mostly safety, I have small kids. Can’t let $140 get in the way of a little piece of mind. Hell at least I know they’re good for 14 years.
    I bought all OEM parts from Toyota Dallas. I ordered last week two Toyota remanufactured calipers ($100 each after core return) as my seals were toast and had been for some time. And Toyota pads. All new under all four corners. Drums/shoes/cylinders were done last summer.
  7. Feb 10, 2018 at 9:55 PM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    I thought about that, thinner rotors won’t dissipate heat as well and could crap the bed.
  8. Feb 11, 2018 at 4:18 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Me I just put on new rotors with new pads
    Then bed the pads go to go for another year
  9. Apr 2, 2018 at 8:56 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have to wonder what is wrong with my brakes. I have a 2004. The brakes were done by the dealer at 60,000 miles. The truck now has 171,000 on it and about 6 months ago when I had the tires rotated the shop told me that my brakes were fine. It has always gotten a lot of highway driving though since it was new.
  10. Apr 2, 2018 at 9:02 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    get new...and you can probably get them much cheaper at advanceauto and using a coupon that's easily findable online
  11. Apr 3, 2018 at 4:01 AM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    what is the problem you are mentioning? you are confused why your brakes have lasted 100K?
    Ive replaced brakes that a cust burnt through in under 50K but most of the time they seem to last about 70K to 90K.
  12. Apr 3, 2018 at 4:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    Likely nothing, operationally, if they stop well
    Maybe. I prefer to at least look/measure myself. But it's possible.
    That's the secret. As well as driver habits. Most folks with premature wear have poorly serviced systems or a poorly calibrated 'foot'.
    Always be sure the rear drums are being inspected and serviced/adjusted (if needed) as well. Not only do they tend to be ignored, they have a huge role in overall stopping power. Not to mention extending the life of the front brakes.
  13. Apr 7, 2018 at 9:31 PM
    TRVLR500
    Wyoming
    I should have put a "smiley face" at the end. I was kidding. I'm well aware of these Toyota brakes lasting a very long time. Especially with mostly highway driving as I do and my dad, the original owner, did. It's gotten off-roaded regularly since it was new but nothing extreme. At least not until I bought it at 119,000 miles and I only "thrashed" it when I first got it and not very often. It's a daily driver.
    I will add that 110,000 miles (now 111,000+) since the brake job it had at 60,000 does show some really impressive longevity for Taco brakes when used properly.
  14. Apr 13, 2018 at 3:51 AM
    Tacoma4x4
    Tacoma4x4 Member
    Nino
    Toronto, Ontario, Canada
    2002 Tacoma TRD Off-Road
    None yet
    Where are you folks buying your brake parts? My Tacoma will never get that mileage on rotors or at least Km’s ;) up here in Canada. I’m due for a break job and this time I’m planning on overhauling both front and rear. I will say that I still have my original rear brake shoes on my 1st Gen. with 400,000km’s that’s about 260k miles.
    Can you folks let me know where to buy brake kits or components ? I usually go through my dealer for original manufacturer conponenets.
    Just seeking some advice from you. Thanks In advance.
  15. Apr 13, 2018 at 4:43 AM
    joeyv141
    New Jersey
    Oem brakes are always good, Akabona(im misspelling that) is a good after market brand I have used, another good aftermarket one is textar they are more expensive though.
  16. Apr 14, 2018 at 3:11 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I am to the point I pretty much use Napa Ultra Premium Brake parts.
    I never had any problems
    Local any problems returns are no problem
