Turn Signal Bulb died
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BravesFan, Nov 20, 2010.
  1. Nov 20, 2010 at 1:08 PM
    BravesFan
    BravesFan [OP] The MOST Badass Offroad Truck
    Rob
    Brentwood, TN
    09 Super rock crawler
    Ym turn signal bulb in my headlight died, so i need a new one. I have ebay bhlm, but the bulb should be the same as oem right? where should i get one, from the dealer or what, and does anyone know the part number? thanks....
  2. Nov 20, 2010 at 1:14 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2014 DCSB TRD 4x4
    pull the bulb and take it in to any autoparts store and they should have one
  3. Nov 20, 2010 at 1:20 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    If all your OEM wiring fit in the Ebay headlight assembly, the bulb is the same. Don't go to the dealer for a bulb, go to any auto parts store. Bring the bulb in with you and match it up or someone there can help you.
  4. Nov 20, 2010 at 1:24 PM
    BravesFan
    Rob
    Brentwood, TN
    Alright thanks
  5. Dec 1, 2010 at 1:04 PM
    BravesFan
    Rob
    Brentwood, TN
    dumb question, how do i take the bulb out, i tried just pulling it out and i wont come................, do the black tabs on the sides have to do with anything?
  6. Dec 1, 2010 at 1:07 PM
    rex99
    rex99 Well-Known Member
    TArdCOMAWORLD
    Proton Cruiser
    Rocket Boosters, Flux Capacitor, Escape Pod, Throttle Body Spacer, Homeroshi, ATRAC disable
    did you change the blinker fluid??
    :rimshot: come on, somebody had to....
  7. Dec 1, 2010 at 1:10 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    turn the connector on the back of the headlight assembly and the bulb will come out with it
  8. Dec 1, 2010 at 1:14 PM
    BravesFan
    Rob
    Brentwood, TN
    No like how do u get the bulb out from teh plastic part connected to it....
  9. Dec 1, 2010 at 1:15 PM
    jhodge83
    SC
    17 XLT Sport
    for the bulf from the connector, just pull straight out. i'd recommend wearing gloves in case you squeeze too hard and bust it. make sure when you put the bulb back in that you feel it click into place and doesnt fall out.
    (sorry i cant see the pic as it's blocked at work)
  10. Dec 1, 2010 at 1:17 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    AFTER you remove the whole assembly, turn the plastic piece and the bulb and plastic piece will come out together. then hold the plastic in one hand, and the glass bulb in the other and GENTLY pull untill they come apart. hten take that bulb to your local auto parts store and they will get you a replacement for less than $2
  11. Dec 1, 2010 at 1:17 PM
    Pugga
    Massachusetts
    F-150 Mod
    There's usually a tab holding the bulb in. You can use a flathead screw driver to GENTLY lift up on the tab and pull the bulb out. If you lift too hard you'll break the tab so be careful (you can still plug in the new bulb if you do manage to break the tab, I broke one of mine and haven't had any issues yet:eek:)
  12. Dec 1, 2010 at 1:27 PM
    BravesFan
    Rob
    Brentwood, TN
    Alright i got it, i guess i wasnt pulling hard enough the first time, thanks
