Turn Signal Doesn't Work When Brakes Applied
Discussion in 'Technical Chat' started by jrich44, Feb 27, 2012.
  1. Feb 27, 2012 at 10:07 AM
    jrich44
    jrich44 [OP] Well-Known Member
    96 Tacoma 2.7L
    I have been having a strange problem with my driver's side turn signal recently, it functions properly only until the brakes are applied. The passenger's side blinker works just fine, but if I try to signal a left turn and use the brakes at the same time I either get no blinker or a very slow blinker.
    The first thing I tried was to replace the bulbs, where I replaced both driver's side turn signal and brake bulbs in the taillight assembly. This seemed to fix the issue for a couple days, then the problem came back.
    Next, I was thinking that either there is a bad ground somewhere or maybe a bad flasher. I would think that a bad flasher would cause the problem on the passenger side as well, so I'm not sure that's it. Has anyone had this problem, any input is appreciated.
  2. Jun 5, 2012 at 11:28 AM
    BigSurTaco
    BigSurTaco Member
    Torre
    Big Sur, CA
    03 sr5 4cyl 4x4 2" lift
    K&N, 2" suspension lift
    I would like to bump this as I'm having the same problem... my driver side blinker is also stuck on when i turn on my headlights???
  3. Jun 5, 2012 at 12:20 PM
    knucklehead
    knucklehead Well-Known Member
    Jeff
    Ottawa
    SR5 4x4
    Hitch, nav header
    How about you remove your aftermarket trailer wiring converter and see if that fixes it?
  4. Jun 5, 2012 at 1:48 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you don't have the trailer wiring, start looking for shorts and grounds between the problem circuits. A missing or loose ground will cause some strange symptoms.
  5. Jun 6, 2012 at 7:43 PM
    BigSurTaco
    BigSurTaco Member
    Torre
    Big Sur, CA
    Thanks guys. I shoudn't have bumped this. I kept searching and found a thread with exactly what what you guys are saying... search search search
  6. Feb 7, 2013 at 7:42 PM
    Rawbeet
    Rawbeet New Member
    Okanagan BC
    01 Prerunner SR5
    I just had this start to happen to me can someone tell me what to check or point in the direction of that other thread?
