Turn signal/DTRL bulb MELTED! Second time now, advice needed
Discussion in 'Lighting' started by nvtaco, May 11, 2012.
  1. May 11, 2012 at 3:18 PM
    nvtaco
    nvtaco [OP] Well-Known Member
    Vancouver, BC
    07 Double Cap TRD Sport
    Vent visors, backup lights, the loadhandler!
    Hi All, my drivers side bulb signal bulb went out. When I removed it the black plastic was melted quite a bit and the orange bulb looked like it had a fire in it.
    Replaced the bulb, within 1 hr. the same thing happened, obivously a short but how would I check for that? Has anyone else experienced this and fixed it? thanks
  2. Jun 10, 2012 at 7:00 PM
    SamS
    SamS Active Member
    Vancouver Island, BC, Canada
    06 Access cab 4x4
    Same thing. My front driver side signal bulb/DTRL burned out a couple months ago. It too looked like the whole socket had been quite hot. Now the replacement bulb is burned out too, with a lot more damage to the socket. Now I'm having a hard time keeping a new bulb maintaining connectivity with the socket.
  3. Jun 13, 2012 at 5:39 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    Most auto parts stores will sell a replacement bulb socket. Wire it in and you will be good to go.
  4. Jun 13, 2012 at 5:43 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Sounds like you should switch to an LED bulb. They won't burn hot like the filament ones do.
  5. Jun 13, 2012 at 2:11 PM
    spinso71
    spinso71 Member
    Shawn
    Baton Rouge
    09 Tacoma 4X4
    I saw my DRL lenses had melted and found out that since I'm out of warranty Toyota won't fix the issue. However, I replaced the DRL bulbs with LED's since they don't run hot. Now, my blinkers blink twice as fast. Any suggestions on correcting this? Is there any danger to the electrical system?
  6. Jun 14, 2012 at 9:37 AM
    Rellik01
    Craig
    Windermere, Florida
    resistors
  7. Jun 14, 2012 at 9:21 PM
    mavrick0509
    mavrick0509 Well-Known Member
    Hallettsville, Tx
    09 TRD Sport 4x4
    3" Suspension Lift, 285-75-17 Nitto, Painted Sport Wheels, Retro Projectors, Elusive Elements Grille, Flowmaster Muffler Swap
    X2 PM csjumper2003 he'll take care of ya
