Turn Signal Flash x3, is it possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by voz, May 19, 2014.
  1. May 19, 2014 at 5:03 PM
    voz
    voz [OP] Nothing Witty To Say
    VOZ
    VOZLAND
    The Clean One
    In Progress, Progressively
    I recently rented a 14 Corolla, when you hit the turn signal lever once it flashes it three times, like BMW & MB...
    Is it possible to make a Tacoma do that?
    I own a 528i and have become fond of this feature.. I find myself hitting/tapping the lever only once when changing lanes..
    Is it just a relay?
  2. May 19, 2014 at 5:22 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The signal is controlled by a relay. Find out if the corolla has the same design and if yes, plug it into your truck. Relays are cheap, that wired flash might be a little more money, but I bet you could get one over the internet for less than $25.
    IM curious. Do it and report back.
  3. May 19, 2014 at 5:30 PM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    My 13 altima and 13 silverado both did this and miss it report back please
  4. May 19, 2014 at 5:33 PM
    koditten
    Kirk
    Central Michigan
    You say your car has this feature, check to see if the relays have the same electrical contact configuration. If they are the same, swap them out. You can find out right away.
  5. May 19, 2014 at 5:35 PM
    Rsoxfan1
    Rsoxfan1 Well-Known Member
    Mass
    2012 DCSB TRD Sport 4x4
    I'm pretty sure it's going to require more than a relay...I think it's controlled by a module....
  6. May 19, 2014 at 6:11 PM
    voz
    VOZ
    VOZLAND
    The Clean One
    Corolla was a rental,
    I have a BMW 528i that has it and my old MB had it also...
    I will try to call my buddy at our local toyota dealer..
  7. May 19, 2014 at 6:15 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    This isn't a relay issue. The turn signal you had is more or less a 2 position switch. You would need some sort of module that would allow ours to do that. Or else try to rig up the control box from a Corolla to our lever. Sounds like a lot of work to me. It is a noce feature though I will admit.
  8. May 20, 2014 at 5:05 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It would have to involve a counter that is set to the number of flashes desired. The signal from the stalk would set the counter which would energize the flasher the flasher output would decrement the counter from the set count to zero at zero it would stop flashing. This would involve interrupting the normal circuit path or at the very least paralleling the existing circuit.
    Very doable for someone with an understanding of electricity and circuits.
    These are very easy to setup: http://www.ia.omron.com/product/item/h3ca1001b/
  9. May 20, 2014 at 6:27 AM
    memario1214
    Colton
    Missoula, MT
    Then you'd have to hold the stalk down if you want continuous blinkers not?
  10. May 20, 2014 at 6:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm pretty sure Memario has it right, it's the switch that would need to be replaced. You don't need a counter, a timer would suffice. You know 3 flashes takes X amount of time so set the timer to allow electricity flow for that amount of time. My Ford has this feature, if I press the stalk down slightly, it flashes 3 times, if I push it down harder, the blinker stays on until I make a sharp enough turn or turn it off manually. I would bet the switch is the control in this case.
  11. May 20, 2014 at 6:51 AM
    Bender581
    Bender581 Well-Known Member
    AL
    Arkansas
    2012 4X4 Tacoma
    Gobi roof rack. Icon coilovers, Icon tubular UCAs, FOX 2.0 rear shocks, Icon 3-leaf progressive AAL.
    My wife's Rav4 has this feature. It is programmable to flash 1, 2, or 3 times when you lightly press the blinker switch. This change can be done by the owner. Some one on the Rav4 forum says you can take it to that dealer, and they can program it to flash up to 5 times. I haven't played with this feature. She doesn't like me playing around with her car.
  12. May 20, 2014 at 8:40 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No, not if you run the counter circuit in parallel.
  13. May 20, 2014 at 8:45 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I didn't say that they did it with a counter explicitly. I said you could use a countdown counter and run it parallel with the existing circuit. The same would hold true if pressed down slightly it would trigger the counter for set # of blinks. If pressed all the way the turn signal would operate normally with the exception that it would give three additional blinks before turning off.
    Yes, you could also do the same with a timer...
    Unlike Memario, I think if you really wanted this it would be relatively easy to do.
  14. May 21, 2014 at 2:44 AM
    memario1214
    Colton
    Missoula, MT
    Its a cool feature for sure. Im more than happy to be proven incorrect. :)
  15. May 21, 2014 at 4:48 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    If I get time tonight at work I'll see if I can dummy up a rough idea of what I am taking about.
    DTRL or No DTRL will make a difference.
  16. Sep 4, 2015 at 9:43 AM
    cseaman
    cseaman Well-Known Member
    Atropia
    2019 RS3, 2019 SQ5
    Anyone ever have any luck with this, or find any products to do it?
  17. Sep 4, 2015 at 10:04 AM
    Kelvin
    Kelvin Wheeeeee
    16’ GX460 with some junk bolted on
    People use their signals in socal?
    PzTank likes this.
  18. Sep 4, 2015 at 10:41 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
  19. Sep 9, 2015 at 8:34 AM
    voz
    VOZ
    VOZLAND
    The Clean One
    Interesting...
    Q: Can I install the One-Touch Signals module on any car?
    A: Most new cars use a computer to run the turn signals. The turn signal stalk sends a ground input to the computer. Find a wiring diagram of your car, or use a volt meter or test lamp to determine which wires on your car go from the turn signal stalk to the car's lighting computer. If that signal goes to ground when you move the stalk for right and left turn, then you can install our module and control the number of flashes you get for a One-Touch sequence.
    Does anyone know if the signal for a tacoma goes to ground?
    If not does anyone have the wiring schematics?
  20. Sep 9, 2015 at 8:50 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Just buy a 2016. They're set up like this.
