Turn Signal Flasher Relay
Discussion in '1st Gen. Tacomas (1995-2004)' started by TejasYOTA, Jan 12, 2014.
  1. Jan 12, 2014 at 5:08 PM
    TejasYOTA
    TejasYOTA [OP] Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    After installing my LED turn signals on my front bumper and after a handful of months of listening it run super fast.
    I gotten tired of it and looked into slowing it down.
    Yes I know about the RELAY modification, but I did not want to go down that route.
    So a quick check on the inter-web and I found that there was a relay replacement that will work with LEDs!
    $13 and 15 mins later… all done. :D
    Easy cheesy!
  2. Jan 12, 2014 at 7:16 PM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
  3. Jan 12, 2014 at 8:37 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Got the exact same one!
  4. Jan 13, 2014 at 9:08 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    wish i woulda seen this before i installed resistors on my blinkers.. oh well.
  5. Jan 13, 2014 at 1:07 PM
    kemosabee
    kemosabee Well-Known Member
    James
    Pagosa Springs, CO
    07 Tundra TRD 4x4 / 01 Turd 4x4 / 14 Rav4
    500 extra HP of stickers
    Since I recently upgraded mine to LEDs I saw this post this morning and was surprised that the auto zone here had them! Thanks for the write up!
  6. Jan 23, 2014 at 12:18 PM
    gman2530
    gman2530 Well-Known Member
    San Diego, Ca.
    04 PreRunner
    Got mine today! Thank You!!!!
    Ordering front LEDs now..
    When i called Auto Zone, they advised that tridon is being changed to nouvto??? something like that, Same Part number, same packing..
    I got their last one with Tridon on the Flasher..
  7. Jan 23, 2014 at 1:41 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    subbed for when I install my bumper and put LED turns on it. Thanks!
  8. Jan 23, 2014 at 2:31 PM
    FALlover
    FALlover Well-Known Member
    luziana
    98 tacoma SR5, camo paint
    trail gear bumbers, warn 9000
    i need to do this, thanks.
    posting so i can find it later :)
  9. Feb 2, 2014 at 9:14 PM
    Rubio92
    Rubio92 Well-Known Member
    Josh
    Bakersfield, CA
    '04 Prerunner IMPULSE RED
    Projector Retrofit in sig LED's galore inside and out Painted black stock alloys
    Sweet! Thanks Tej, now I can ditch my resistors. I thought it was WAY more complicated!!
  10. Feb 11, 2014 at 12:49 PM
    Rubio92
    Josh
    Bakersfield, CA
    I just did this last night, perfect. A little faster than stock, but I'm not complaining. Better than those bulky resistors. Thanks a ton!
  11. Feb 13, 2014 at 6:35 PM
    Rubio92
    Josh
    Bakersfield, CA
    Worked for me. If you have LEDs as turn signals at all, anywhere on your truck...this EASY mod corrects it.
  12. Feb 13, 2014 at 6:37 PM
    ffirg
    mike
    Anchorage, Alaska
    What if you only have LEDs on the front?
  13. Feb 13, 2014 at 6:44 PM
    Rubio92
    Josh
    Bakersfield, CA
    They'll hyper flash. Two LEDs up front, regular out back, or vice versa...they'll hyper flash. I'm running LEDs up front and regular incandescents in the back, with the flasher relay, they hyper flashed. After the EP35 relay, no hyper flash.
  14. Feb 13, 2014 at 6:47 PM
    ffirg
    mike
    Anchorage, Alaska
    Ok cool, that's what I was wondering. I'll be using two rigid A series as turn signals up front but stock lights in the rear.
  15. Feb 13, 2014 at 8:08 PM
    Rubio92
    Josh
    Bakersfield, CA
    I was thinking of the exact same thing! 2 Rigid dually's, amber for turn signals. Well, that's for when I get my tube bumper down the line a bit. Kind of over kill and would put every Audi and BMW to shame...well, front turn signals anyways.
  16. Apr 28, 2014 at 11:48 AM
    NolaTaco42
    NolaTaco42 Well-Known Member
    New Orleans
    08 PreRunner
    4" lift 17x9" XD Hoss wheels on Nitto 285/70/17 Trail Grapplers
    This fuse box looks different than mine. I'm having a hard time getting the the back of it. I have an 08
  17. Apr 28, 2014 at 3:22 PM
    Rubio92
    Josh
    Bakersfield, CA
    I'm sure it's different, but by how much I'm unsure of. The '05+ are different than the '96-'04 Tacoma's.
  18. Aug 25, 2014 at 8:20 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
  19. Aug 25, 2014 at 8:29 AM
    BamaToy1997
    Bill
    Navarre, FL
    This is a thread a few months old, but I would like to add that you can get these relays at Superbrightleds.com since last August. They have the right ones for your application, and now they are showing that they have the flashers for those with DRLs, which have a larger connector on their flasher.
  20. Aug 26, 2014 at 10:00 AM
    bobbyworks
    bobbyworks Member
    I have LED front signal lights, I installed resistors as well as this EP35 Relay mod, the turn signals are slow and fine UNTIL I press the brake pedal - for example if I am turning left at an intersection and rolling the turn signal is fine, but as soon as I press the brakes the turn signals go fast!? anyone have any ideas?
