Turn Signal / Flasher Stopped Working
Discussion in '1st Gen. Tacomas (1995-2004)' started by jadesride, Nov 25, 2022.
  1. Nov 25, 2022 at 1:46 PM
    jadesride
    jadesride [OP] Member
    This has probably been covered before but -
    2003 4x4 Regular Cab 2.7
    Recently the right front turn signal and flasher stopped working. This is only the right front. I have replaced the bulb with a known good bulb. No physical damages. The wiring looks fine.
    Possible causes - fuse, relay, column switch, broken wires, etc.
    Any thoughts on the likely culprit? Or where to look?
    Thanks for your help.
  2. Nov 25, 2022 at 1:49 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Have you checked the power and grounds on the bulb socket?
    This will help narrow down the direction to take to properly diagnose the issue.
    Green/Yellow wire is power
    White/Black wire is Ground
    You could also try the Hazard switch to see if it works then.
    If so, the problem is likely the turn signal switch.
  3. Nov 25, 2022 at 6:17 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I venture corroded socket which might test good with the meter.
    My first go to is to check the hazard lights see if they work.
    wilcam47 likes this.
  4. Nov 26, 2022 at 12:07 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    my left blinker would sometimes go into this high speed blink....like the relay was frying....
    Mine turned out to be the column switch......got worse over time....
    the simplest forward...
  5. Dec 2, 2022 at 9:52 AM
    jadesride
    Thank you for replies -
    It did turn out to be a heavily corroded socket and plug - both caked with blue corrosion.
    New plug & socket and it's good to go for another 20 years - or maybe more as it is now weather sealed.
    Bivouac and wilcam47 like this.
