Turn signal fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by neontrail, Apr 18, 2008.
  1. Apr 18, 2008 at 1:11 PM
    flavalk
    flavalk 2-Broke 2-Care
    Orlando, Florida via Huntsville, Alabama
    '07 PreRunner SR5 Double Cab 2WD - Short Bed - Automatic- Silver Mica
    Not much. Toyota bed mat, Toyota step bars, tinted windows, Toyota seat covers, Toyota all-weather mats, quart of Wild Turkey in the glove box, KelTec PT3AT in the center console, backseat full of old speeding tickets
  2. Apr 18, 2008 at 2:49 PM
    RedruM29
    RedruM29 Blinking Car Mod...
    Kyle
    Nor☆Cal
    08 trd sport 4x4
    Just enough, and never enough
  3. Apr 18, 2008 at 3:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i loaded the truck up with traction grease this morning, so i should be good for at least 10k miles!!!
  4. Apr 19, 2008 at 10:19 AM
    Pootz
    Pootz Active Member
    Calgary, AB
    2008 Access Cab V6 4X4
    I'd really like to get myself one of those radiator insulators because I could really see that increasing your power through reduced heat loss but $199 is a bit steep. Does anyone have any idea what they use for insulation? Maybe a guy could make a homemade version by just slapping a pillow one either side of the rad and duct taping it in place. Maybe some fibreglass house insulation? What do you guys think would work best?
  5. Apr 19, 2008 at 11:07 AM
    rick
    rick `
  6. Apr 19, 2008 at 11:28 AM
    lightmup
    lightmup Well-Known Member
    Utah
    07 db cab TRD sport 6" fabtec lift 33-13.5-20
    AFE intake, Gibson cat back exhaust, Fabtec 6"lift, King remote resy coilovers, Light Racing UCA's , Allpro front bumper,PIAA fogs, 3 KC slim lights, Optima battery, Weathertech flour mats, Tinted windows, Wheels and tires, Back up camera, 10" shallow mount kenwood sub
    I have to get a round tuit. It sounds like it can make life a lot more productive.:rolleyes::rolleyes:
  7. Apr 19, 2008 at 10:30 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Those radiator fins really cause some incredible heat loss. You might try wrapping it with an electric blanket; that's what I did. You can find them at Walmart pretty cheap. Of course, you'd have to get an AC/DC converter, or run a long extension cord if you have the outlet in the bed. I can't believe Toyota would make a radiator that loses so much heat. They obviously didn't think it through.
  8. Apr 20, 2008 at 6:40 AM
    neontrail
    neontrail [OP] ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    LMAO..I could NOT read that with a str8 face! ..Great post!
  9. Apr 20, 2008 at 8:10 AM
    Pootz
    Pootz Active Member
    Calgary, AB
    Wow! I never even considered an electric blanket. That would be twice as effective, you'd think. I'll have to give that a shot. Did you route your cord under the vehicle to the outlet or do you think there's a way to hook it up straight off the alternator?
  10. Apr 20, 2008 at 9:36 AM
    mrbjr
    mrbjr Active Member
    Central CA
    '08 DC V6 4x4 TRD Sport
    TRD Exhaust,TRD Sport seat covers, Tube steps,Access Limited Bed Cover,WeatherTech floor mats, Billet Grill,AFE CAI,8"Shorty Antenna,ScanGaugeII.,5100s f/set @ .85, Console Safe.., Pirelli ATR's..,RoadMaster active suspension
    Has anyone else tried the '65 Volkswagen radiator swap yet? I'm having a bit of trouble getting the spacers lined up...:mad:
  11. Apr 20, 2008 at 10:46 AM
    spp
    spp OC, Kalifornia
    OC California
    Not yet. I have to wait until my father in law sells me his 1965 then I'll check that out.;)
  12. Apr 20, 2008 at 1:53 PM
    Evil Monkey
    Robert
    Escondido, CA
    You probably couldn't wire it directly off the alternator as it's a DC source whereas most electric blankets are AC. I routed my wire around the exhaust pipe. The heat of the exhaust makes the wiring's insulation extra sticky and causes good adhesion so it stays in place.
    To hold the blanket on, I just took a roll of duct tape and wrapped it around the radiator. That also provides a good wind block as most electric blankets still let some air through. When you're done, be sure to spray paint it black so it looks good through the grill, especially if you have a Grillcraft.
    It works good. I mounted the controller in the cab of my truck near the window controls for easy access. That way, I can adjust the heat to get it quickly in the red. When the engine reaches the "H" on the gauge (heated), I know it's ready to go. I've included some pictures below. One shows the controller placement and the other shows my blanket wrapped around my radiator just prior to painting. I found this blanket on sale. I went with the purple plaid as I think it goes better with duct tape.
  13. Apr 20, 2008 at 2:01 PM
    mrbjr
    mrbjr Active Member
    Central CA
    I'm starting to get a little afraid that an awful lot of us have too freakin much time on our hands:rolleyes:
  14. Apr 20, 2008 at 10:28 PM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    Wow...and everyone was actually really scared for the guy, myself included!
  15. Apr 21, 2008 at 9:36 AM
    #35
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    Ok big question, has anyone tried to order anything yet? i tried to add some stuff to my cart today and check out but it said i needed to log in first. the last thing i need is to get more random emails from some stupid site, so there is no way i'm logging in. but has anyone actually gone through the trouble to log in and try to order? i just want to see what happens
  16. Apr 21, 2008 at 9:59 AM
    #36
    2003greenbean
    2003greenbean Carolina Alliance Costal Div
    socaste,sc
    03 trd
    cold air intake, step bars, custom grill, 3in lift,12 in audiobahn sub, 285/75/16 procomp tires, 20% tint,
    let me know if you get loged in i want you to order the engine oil bypass kit for me and bring it to the meet
    the best part is the reviews of this stuff
  17. Apr 21, 2008 at 3:03 PM
    #37
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I'd pass up on the radiator blanket right now if I were you.
    I've got the inside scoop, as I just sold them the patent rights to the
    Double Add-a-Cylinder Kit.
    You just bolt it on and you'll make your V6 a V8!!:eek:
    No drilling or cutting required!
    The slant kit is required for I-4 engines.:(
  18. Apr 28, 2008 at 1:12 AM
    #38
    Manofs
    Manofs Well-Known Member
    best site ever!!!! i am definately going to save up for that truck to tank kit.....
  19. Apr 28, 2008 at 10:34 AM
    #39
    FamouzStarz
    FamouzStarz The illest taco
    21 TRD PRO
    ICON Build and then some
    im saving up for the boost bar!!! whoo hooo
  20. Apr 28, 2008 at 11:49 AM
    #40
    96Tacoma4x4
    96Tacoma4x4 Well-Known Member
    Memphis, TN
    96 xcab 4x4 LX stock
    32x11.50 and K&N filter drop in
    Hey, has anybody seen those Solar Heated Headlights? I can't find them anywhere. They say these lights will increase your gas milage as much as 50%. I was curious if anybody has them.
