Turn Signal/Hazard Issues
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CactusTaco, Dec 6, 2021.
  1. Dec 6, 2021 at 7:46 PM
    CactusTaco
    CactusTaco [OP] New Member
    2014 Crew Cab Short Bed
    I decided to upgrade all my bulbs to LED. I didnt know that the turn signal bulbs are CK. I installed some standard socket LEDs and blew fuses. First I blew the fuse under the hood, then I replaced that. Then I blew the fuse in the cab, then I replaced that. At that point, my turn signals and hazards stopped working, but the two signal bulbs in front were on all the time. Which seemed weird because they were standard socket bulbs in CK sockets. I took all the bulbs out and replaced the turn signal/hazard relay with an LED compatible one. That fixed the turn signals/hazards. I got CK bulbs and installed them. The rears work great but the fronts are not working and I have no voltage. The 2 fuses I know about look good. I downloaded the wiring schematic and there are some possible culprits, but I havent had a chance to really get into it. Anybody got any suggestions?
  2. Dec 6, 2021 at 7:54 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Kind of confused on what’s not working?
    Is it the front turn signals that don’t work?
    Also, do you have Daytime Running Lights?
    If so, I wasn’t aware of a flasher relay compatible with the DTRL trucks?
    whatstcp likes this.
  3. Dec 6, 2021 at 8:13 PM
    CactusTaco
    The two lights closest to the grill are the only thing not working. They usually flash for turn signal/hazard and stay on constant for parking lights. I dont have DTRL.
