Turn Signal Hyperflash without LEDs???
Discussion in '1st Gen. Tacomas (1995-2004)' started by becker.adam2, Mar 29, 2020.
  1. Mar 29, 2020 at 9:05 AM
    becker.adam2
    becker.adam2 [OP] Member
    Adam
    2000 Toyota Tacoma SR5 3.4L V6
    I have 2000 V6 SR5.
    When I bought it, the turn signals didn't work at all. After replacing the front 2 bulbs (not LED bulbs) they work fine, but they hyperflash.
    The only things I can think of are that maybe the rear turn signals are running LEDs, or maybe the aftermarket stereo head is causing this? There is what appears to be an aftermarket trailer wiring setup in the back that might also be causing this? Maybe I should just upgrade the electronic flasher relay?
    Any ideas or wisdom on this is appreciated. Thanks!
  2. Mar 29, 2020 at 9:20 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Hyperflash is generally associated with a burnt out bulb. Are all the lights lighting? If so, then you might have an LED on your hands.
    becker.adam2[OP] likes this.
  3. Mar 29, 2020 at 12:26 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    try swapping the bulbs for one another. I had hyperflash issue last year, despicte running no LEDs anywhere on my truck.
    Switched the bulbs out just to see and the problem ended up being a bad bulb. Was not burnt out or anything, it was lighting up normally when tried on the reverse lights, but whenever it was put back on the blinkers it would cause them to hyperflash. Something must have been shorted inside the bulb, I don't know
    if it's not your bulbs and you have no LEDs, I would say it is the trailer wiring. These controllers sometimes do funky things to lights
  4. Mar 29, 2020 at 12:40 PM
    becker.adam2
    Adam
    Swapped out the bulbs one at a time and it fixed it. Must have been the same problem. Thanks guys!
    onakat likes this.
