Turn signal illuminates when I brake
Discussion in 'Lighting' started by akjeff, Mar 12, 2009.
  1. Mar 12, 2009 at 8:08 PM
    akjeff
    akjeff [OP] New Member
    As I slowed to a stop this evening in my garage, I noticed a yellow light on the wall. After having some help from a neighbor, I noticed both driver's side turn signals illuminate (no flash) when the brake pedal is depressed. I had a 7 way trailer wire harness installed over a year ago-no problems with it with. I glanced at it and it does not appear to be damaged. Any help would be greatly appreciated.
    Jeff
    ETA: 2008 DC 4x4
  2. Mar 12, 2009 at 8:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What year truck??
  3. Mar 24, 2009 at 11:44 AM
    itsmyturn
    itsmyturn Well-Known Member
    Victorville, CA
    08 dbl cab TRD sport
    afe Pro-Dry S dropin, Readylift leveling kit, TRD skid plate, Alpine CDA-9887, 6K D2S HID
    did you replace any turn signal or brake light bulbs recently? the wrong bulb could cause other lights to turn on when energized.
  4. Mar 24, 2009 at 11:50 AM
    98tacoma27
    Ben
    Not Beech Creek
    It sounds like you have exposed wires somewhere that are touching. Trace the wires back from each headlight to where they join and check there.
  5. Mar 24, 2009 at 12:11 PM
    L8Rmike
    L8Rmike Well-Known Member
    Goose Creek, SC
    08 White DC LB 4x4 sport
    Welcome to TW! Start with the bulbs. I have had one filament in a two filament bulb brake and lay on the good filament. When the good filament circuit is energized it also will energize the bad filament circuit.
  6. Mar 24, 2009 at 12:19 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Neato...
