Turn signal issues again
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sam Amburgey, Jan 2, 2013.
  1. Jan 2, 2013 at 9:32 AM
    Sam Amburgey
    Sam Amburgey [OP] New Member
    Noblesville, Indiana
    06 TRD 4X4
    K&N air filter
    Need some help. 2006 4WD TRD, 3rd time issue with turn signals. Dealer repaired in warranty first two times. They fixed, not corrected the issue. Right turn signal indicator arrow stays lit, front and rear turn signals are constant on. They do blink, but weakly, and do not go out between blinks. Recently in to dealer for 2nd recall, this time the spiral cable problem. Any ideas? Relay? Switch?
  2. Jan 2, 2013 at 10:30 AM
    BamaToy1997
    Bill
    Navarre, FL
    The turn signal flasher is a small module now, instead of the small "can" of yesteryear. It is located on the left side of your dash. I would be more suspicious of that since you have had a repeat problem, and what appears to be no "flash" control.
  3. Jan 2, 2013 at 10:33 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    blinker fluid is low......jk, you know you had it coming
  4. Jan 4, 2013 at 6:06 AM
    BamaToy1997
    Bill
    Navarre, FL
    :bowdown:
  5. Jan 4, 2013 at 6:08 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Back to the dealer to make them fix it. They warranty their work.
